I have IRiver H10 and windows vista is my Operating system. I downloaded the IRiver device manager and the new firmware but still it says it can't find the driver. I downloaded the driver from the IRiver.com page.. and still can't find it. What do you recomend me to do?I have IRiver H10 and windows vista is my Operating system. I downloaded the IRiver device manager and the new firmware but still it says it can't find the driver. I downloaded the driver from the IRiver.com page.. and still can't find it. What do you recomend me to do?
Just to let everyone know I have the H10 6Gb player and the reason your having problems getting the H10 to work with Vista is because it isn't supported by Vista at all even with updating your firmware...
Try plugging in usb with the H10 turned off. Now, press the select button (with the round symbol on it) while turning the H10 on. This starts the player in 'emergency mode' and should be recognized by XP
To sync your device use either winamp or Iriver plus (winamp is better) -Download winamp from http://www.winamp.com/player -Iriver plus http://www.iriver.com/support/down_view.asp?idx=860 All firmware releases for your H10 can be found at: http://www.iriver.com/product/p_detail.asp?pidx=61
I have lately experienced the same problem with my H10 20GB. I noticed it happened after installing some other software. I think there is an conflict between iriver and apple, I mean iTunes Helper present in memory causes the trouble. I stopped the process from Task Manager and reconnected my H10. It helped. If you don't need iTune Helper you'd better disable "C:\Program Files\iTunes\iTunesHelper.exe" from starting with system.
well itunes only works with the ipod for syncing music, windows media player 10 and 11 is where you would sync you music i would add your music to the media player library and go from there
Hi Vera
I am using windows2000 OS, can not yet justify a faster Pc to run XP .. following is what I use to load and manage my MP3 audio files on my H10 20GB
>using an alternative to WMP 10, I use 'EasyH10' .. prepares an H10 player without iriver
plus or Windows Media Player 10 based on music and playlist files transferred manually using windows Explorer
easyh10-15.exe
Info re Easy_H10 URL http://www.misticriver.net/wiki/index.php/Easy_H10
URL http://sourceforge.net/project/showfiles.php?group_id=138812&package_id=152796
download 'easyh10-1.5_win32gui.zip'
- connect USB cable between Pc and H10
- place H10 in 'Lock' position
- use a tool ( refashioned paper clip ) to press the reset button
- start H10 in USB Mass Storage Device Mode... Hold down 'O' button, continue holding 'O' button
while you press the 'On / Off ' button until screen displays USB connection, after emergency display
- In Windows Explorer locate the ' removable drive'
- Transfer your music files with tag information to 'Music' directory on H10
- Run EasyH10
- for Media database construction to display songs in MUSIC mode.
- Playlist conversion, a necessary process for your playlist files to become compatible
(recognizable) with an H10 player.
- EasyH10 also imports/exports tuner presets from/to a text file.
Prh
I cannot dowload my iriver h10 on my new computer using vista
I have a i river H320 and Vista o/s will not recognise it, help req.
it wont read my iriver at all nothing wiillll
I downloaded the device driver and it will not recognize my iRiver
