Single Split Wall Type Air Con Blows 15A CB as External Fan starts. Short in Fanmotor or Cap?
    Top Expert:
  • 12,761 Answers
What size a/c ? will assume under 10,000 btu if cb blows on fan only and fan not turning assume fan problem caps will let fan hum like trying to start but a 15a seems low for a window unit also anything else on circuit best way to determine is use an amp probe to see how many amps are being drawn if amps peg meter on start a winding or short in motor
Posted on Oct 07, 2009
Cleaning my split system
We recommend you get it serviced regularly by an air conditioning company.
You need to spray anti bacterial spray and change the filters to service your air con.
Jul 20, 2017 | Sanyo Heating & Cooling
Split type aircon
It sounds to me that the air con is on auto fan, as the room gets hotter or colder the fan will slow down and stop. keep the fan on low,med or high fan speed
Apr 02, 2014 | Carrier Heating & Cooling
Air con dead
Larger split system air con gets power from the external unit while smaller air con gets power from the internal unit. Can you find any power switch or power socket/plug around the external or internal units?
Nov 19, 2013 | Cell Phones
The fan is not working
is it a wall through unit a box air con or a split system? does the fan feel stiff if you try to free spin it does it make a noise make sure its turned of when you do this. it could be your capacitor if fan free spins
Nov 10, 2010 | Weather King Heating & Cooling
Show me where the filter is located
dear sir /madam
please know what is type your air-con i mean widow type or split type or Central air conditioning's unit .if your air con is window type air conditioner then remove cover (grill) and find there is air filter if your air con split type of then open its cover there down side of cover there.is filter located
if air con is central cooling unit the find out your filter in duct side i mean air blower side where fresh cool air going to your room .
use this method i hope you will find solution of your problems
thank you
please vote!
Sep 06, 2010 | Heating & Cooling
Require specifications for an Emailair split level air con model CWS 034A
Capacity which normaly known as Horse Power
or RA rating
The voltage input
Ampere ratings
voltage phase ex. (single phase or three phase)
Type: Split type
since it is split type there are several classification(wall mounted, foor mounted or ceiling mounted)
Oct 31, 2009 | Heating & Cooling
I have a fac106p1 eng2, overheating fan motor
first check the capacitor measure, see if measurement correspond with its label ex. 40 mf or 50 mf. I believe the winding for the fan motor are loosing its insulation, you might need to replace the fan motor, if installing new one follow the diagram and rotation their is an arrow indicating the rotation of the fan blade
Jul 23, 2009 | Frigidaire FAC106P1 Thru-Wall/Window Air...
New split system blows only hot air
Assuming it is brand new, are you certain that the compressor does not run at all or is it simply not pumping? Even being new, it is possible that the main compressor capacitor is faulty, this is on the top of the outdoor unit, replace and check.
Jan 29, 2009 | Heating & Cooling
LG C12AWR Air conditioner head fan not working
Check that the fanmotor can spin freely. If not, can be caused by seized bearing on left side of fanblade, or foreign object, insect nest stuck in fanblade. If however it spins freely, check that fanmotor is being supplied with voltage (you sound technically capable of operating a volt meter). If power is supplied, fanmotor is faulty and needs replacing. If no voltage, problem lies with the pc board. If you know someone who is capable let them check the relays on the board. Also you can check that all plug on connectors are making good connection.
Jan 01, 2009 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
