Question about Craftsman Garden
How do you remove cluth on weed trimmers - Craftsman Garden
  • 437 Answers
You will need a small punch and hammer to unscrew the clutch on the driveshaft. There is an arrow on the clutch showing the direction to tap the clutch to take it off. You may want to use PBBlaster or Deep Creep penetrating oil to help you get it off.
Posted on Oct 07, 2009
Worx electric grass trimmer / edger wg116 restring. Need this one not 117.
Demonstrated on a Worx String Trimmer - YouTube
? 3:55
www.youtube.com/watch?v=fFt3a3St54U
Jul 9, 2014 - Uploaded by EricL5150
This is a video on how to replace weed wacker string trimmer line in a string trimmer/weed wacker. ... This is done on a Worx string trimmer but the process is pretty much the .... How torestring dual-sided spool lawn weed eater trimmer with ... Worx56volt Cordless Trimmer Edger Review & Demo Video ...
Sep 18, 2015 | Worx Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    How do I change the string on a wheeled weedeater brand trimmer
    Purchase precut pieces of string. Check the dealer or or big box store for the correct part. The precut string is easily clipped in. Remove the old piece by pushing back and lifting up on the piece until it comes loose. Put the new piece in the slot and pull it forward to seat it. Repeat for the other side(s)
    Oct 19, 2014 | Weed Eater Wheeled Weed Trimmer 961720006...
    STIHL WEED TRIMMER
    With the plug removed the starter should pull very easily. When trying start did the cutter head try to spin? If yes clutch springs may need replacement
    Jul 24, 2013 | Garden
    Ss30 ryobi weed eater fuel ratio
    I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
    Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    I have a craftsman 32cc weedwhacker trimmer and its brand new and it hasnt started from day one it isnt getting any spark at all
    If you have spark problems, remove the wire and then remove the plug, reattach the wire and ground the plug to the engine and pull the string, you should see arc and hear it pop, if not, take the plug to another piece of equipment and remove that equipment's plug wire and attach it to the plug from the weed ******* and then ground it and test it. If still no spark, then plug bad, if plug then the weed ******* has a problem with the spark plug wire or the ignition coil.
    If you have spark at first test, then the problem with the weed ******* is somewhere else.
    Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
    St1000/type 1 grass/weed trimmer - How do I remove the head?
    Yes, there should be a lock hole on the base of the bump head, spin around until both holes align and stick a pin through them both and the base will be locked.
    Now spin the head off.
    The new one will come with adapters if you need them.
    Jun 14, 2010 | Black & Decker String Trimmer Cordless 12"...
    Garden Logo
    79 people viewed this question
    Top Craftsman Garden Experts
    Dean Gruber
    Roland W VanLue
    Roland W VanLue
    Dennis Key
    Dennis Key
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
