Need to replace fan motor in my wall heater it's a williams debonair RMR R8ccw11m is the model # for motor
Williams DeBonair wall heater Motor in the unit is a manufactued by RMR model # is R8CCW11M Red, Black, and White wire 1ph 115v 60hz motor casing is round 3 1/4 " Width of casing is 2 1/8" 2 mounting studs stick out 1/2 " Shaft is 3/4" that the fan cage mounts on
  • JOEN45 Oct 24, 2008
    I NEED MOTOR AS WELL. DID YOU FIND A SOURCE??
3 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Posted on Dec 22, 2009
  • 3335 Answers
SOURCE: I have a Williams uniflow recessed gas wall heater model 57DW. The pilot light doesn't stay lit even after thermocouple has been replaced. I suspect the solenoid is bad.
This would be the flame failure device not work / gas valve .
Posted on Jan 07, 2017
Where is the orifice on a williams wall gas heater 290622
Where the pilot is unscrew pilot tube from pilot assembly and inside there it is
Feb 26, 2013 | Williams (5009622) Ceramic Gas Wall...
There is a high pitched sound coming from my heater, even when the thermostat is turned off. The sound is similar to when you are close to an electrical tower. Please advise
If you have a fan blower on your heater, it may be that the motor shaft is stuck and you're hearing the motor humming. Which, if it is, will burn out the motor.
Here's a link to the Williams website. There you can download the Owners Manual for your Model Number heater. There is a good Trouble Shooting Guide in it, which may also provide more info on what's causing the humming noise.
http://www.wfc-fc.com/
Hope this helps you solve the problem.
Feb 18, 2011 | Williams (5009622) Ceramic Gas Wall...
How can I install the heater?
Can you please describe the electrical specifications on the unit and in the manual (i.e. amps, electrical phase (single or 3 phase) and voltage requirement)? This will dictate the install.
Does the unit have a motor or fan?
Dec 28, 2010 | Williams 3003622 Ceramic Wall Mounted...
How do I adjust the temp on a Williams wall heater model # 1043622?
Found this link to a manual for the Williams Wall Heaters...
Model 1043621.05 is LP Gas Model Model 1043622.05 is Natural Gas Model
http://www.hammerwall.com/Download_Manual/3249/
Temperature is set using a thermostat as explained in the above manual.
Use IE Explorer Browser, manual does not display in Google Chrome as a number of other PDF files don't either, must be a bug.
Nov 12, 2010 | Williams Heating & Cooling
High Pitched noise coming from Williams Wall Heater
open it up and you'll see it while its running sounds like fan bearings or fan misalignment may need a new fan motor. if you replace the fan though make sure all power is off before disconnecting
Jan 24, 2010 | Williams 3003622 Ceramic Wall Mounted...
Williams debonair wall heater + pilot light problems
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
Williams wall furnace no longer adequately heats home
A couple thoughts. On some of the wall furnace gas valves there's a knob that you can set for low fire or high fire. If your valve has this make sure it is in the high fire setting. Is the wall furnace controlled by a wall thermostat or a knob on the heater? With the thermostat turned all the way up like to 90, does the burner and fan continue to run or is the burner short cycling. Is the fan clean and running up to speed. Some of the Williams wall furnace had a two speed fan motor so when the fan came on at first it would run on low speed. As the heat exchanger got hotter the internal fan switch would switch it to high speed. Outside of that you would need a monometer to check the manifold gas pressure.
Aug 31, 2017 | Heating & Cooling
Heating & Cooling Logo
640 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
