Need the grate frame for a monarch add on furnace. Can't read which model we have. Are they all the same? Thank you.
    Top Expert:
  • Heating & Co... Master
  • 13,683 Answers
No different size openings but call monarch 800 number give size of opening and description of unit
Posted on Oct 07, 2009
Testimonial: "Thank you for the help!!!!!!!!"
Need to know what filter i need for furnace
This is probably not a factory specified size. You need to look at the return to your furnace. There should be a frame or housing for the filter. Measure it to see what size you need. These are often customized by the installer to meet the configuration of your ductwork. You need to measure how tal and how wide, but also how deep (thick). If possible always get a pleated filter, and not one of those "horse hair" cheap ones.
Jul 27, 2016 | Filter Heating & Cooling
WHAT IS ERROR FRAMING 411?
Errors 001 to 405 and 429 to 435 are data errors. This type of error indicates that incorrect data was sent to the printer, and the printer is ignoring it. Your System Administrator should correct the packet and send it back to the printer. Error 411 is baud rate mismatch. Here's the manual:
http://www.monarch.averydennison.com/support/servdocuments/User_Documentation/9855rfmp/9855rfidoh_aj.pdf
Jun 17, 2014 | Monarch Paxar? 9855 Label Printer
Filter for In-Floor furnace c.1942
A filter stops dirt getting in to the fan not stopping heat on a grate I have only seen I like this before and there was no filter on it .As you know they are very old and very basic . I will talk with a guy I worked onit with see what he can recall.
Mar 17, 2013 | Heating & Cooling
We have a Intertherm Furnace Model # MGHA-056ABCFC-01 Serial # MGH9205-01793 115va 60hz 1ph 5.9amps 1/8hp rpm 1050 We need to find a blower motor and a blower wheel for our furnace. Can you help...
Phone book, refrigeration distributors, call and give unit make model # serial # 1ph 1050rpm 1/8hp and frame type of motor. Usually a belly band. Though any good parts house can get all needed info off of make model serial. You might need to call a few since many will not sell to you if you are not licensed.
Feb 26, 2011 | Heating & Cooling
Why does furnace overheat and the limit switch shuts it off?
Are you in the North East region of US?
For the pass 6 days I saw a lot of postings for furnace and humidifier failures.
Partly is because the weather but the root cause is lack of maintenance.
User think LIFETIME Electrostatic air filter is maintenance free.
That is not true.
It's wash-able and need to be handle with care.
Inspect the air filter and replace it..
Lack of air circulation cause the furnace frame from burning efficient (BLUE FRAME) to orange / red color.
Over time,the temperature sensor will be coated with carbon deposit and record a higher temp reading.
They circuit will activate the fail safe and not allow the igniter to start on.
In your case,limit switch shut itself off.
Here is a LINK to pictures of Weather King temp probes and sensors.
A clean filter and temp sensor will save you money.
Dial back the furnace to 65F until you can get hold of the filter and clean the sensor.
==== If the MODEL TAG is still in plain view then please post it on reply.
Please keep me posted on the fix via email.
Jan 27, 2011 | Weather King Heating & Cooling
Where is the furnace filter located on the furnace of a Goodman Furnace?
Hi, this is a pretty generic answer, so it's really more of a guideline.
Some come attached at the bottom of the furnace, and are generally removed when the unit is installed. If it's there, it pulls out like a drawer.
Most furnaces are installed on a platform, which is really a box (plenum). Below the platform, and opening to the room, is a louvered grate. Air is drawn in through the grate and into the furnace. The grate has clips on it to keep it closed. Loosening the clip(s) allows the grate to be opened. The filter is usually behind there.
Best regards, and hope that this helps,
--W/D--
Jan 21, 2011 | Goodman Furnace Draft Inducer Blower ...
Monarch 1110 price gun
You should be able to locate the service manual at "eserviceinfo.com. It is a free multi part download.
Aug 18, 2009 | Paxar Monarch 9825 Thermal Label Printer
Need Firepower Add On Furnace 2230 operating Manual
you can email me at T.rentnik@yahoo.com i have the firepower 2236......the 2230/2236 is the same manuel.....these are nice furnaces.....i have the manuel just email me
Oct 28, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
