Question about Acer Aspire 3680 Laptop
My power won't turn on. The battery and the cable
My power won't turn on! The battery and the cable adapter will not work properly to allow it to turn on.. Please let me know what I can do. This computer is only one and one half years old.
Acer Aspire 3680
    Problem Solver:
  • 13 Answers
  • Acer Master
  • 32,281 Answers
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Posted on Oct 07, 2009
How do i get my laptop to power on? Have new power cord but still will not power up
There is a possibility that if the battery is shorting out it won't hold the charge or let it power up.
Mar 30, 2012 | Toshiba Satellite L455D-S5976 Series...
Dell Inspiron 1521 battery not charging
Laptop batteries power a laptop when it is not connected to an electrical outlet. If the laptop battery fails to charge when the laptop is plugged into an electrical outlet, the battery is likely dead and needs to be replaced. Unfortunately there is no way to fix a dead battery. However, while a dead battery is the likely cause, it is not the only cause. The AC adapter may be broken, in which case the battery won't charge, or the battery contacts may be dirty and need cleaning. Prior to replacing the battery, perform simple tasks to ensure a dead battery is the cause of the problems.
1.Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2.Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3.Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4.Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5.Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6.Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7.Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
Sep 01, 2011 | Dell Inspiron 1521 Laptop
My lap top powers on and it turns off after a few minutes. The screen does not turn on.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Feb 16, 2010 | HP Pavilion dv6000z Notebook
For some reason my battery lost all power and will not turn on..how can i fix this problem
Jan 02, 2010 | Toshiba Satellite A305D-S6848 Notebook
Power supply is working but no display and pwer in the laptop
Jan 02, 2010 | HP Computers & Internet
Hp nc4200 won`t start
Dec 28, 2009 | HP Compaq nc4200 Notebook
I have ACER ASPIRE 2920, the power suplly can't turn ON
Dec 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Ibm thinkpad R52 laptop no powering on, adapter is ok.
Dec 26, 2009 | IBM Lenovo ThinkPad R52 Motherboard -...
Does not charge or turns on when plugged in to the power.
Dec 23, 2009 | IBM ThinkPad T22 2647 Notebook
HP NC6000 boot failure.Fan starts but quits after 10 secs or so.
Dec 22, 2009 | HP Compaq nc6000 Notebook
Acer Aspire 3680 Laptop Logo
247 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
