Question about Singer CE-100 Futura Computerized Sewing Machine
Singer futura CE-100 4 blinking reds lights
When sewing a straight stitch, the machine will stop and the red light will blink 4 times. Then you can sew again for about an inch and it will do it again. I have rethreaded the machine. Cleaned out under the face plate. I can't find any discription of this error in the book.
  • 2 more comments
  • Anonymous Feb 04, 2008
    blinking red light after a couple of stiches. no error message. I have rethread several time.
  • Anonymous Feb 16, 2008
    Same problem. rethreaded, cleaned out bobbin... still red light flashes . sews fine if your not in a hurry. not sure what to do
  • Anonymous Mar 15, 2014
    My machine keeps blinking a red light on stitch 15 and 16. I unattached the hoop and turned it on and off, but the lights are still blinking.
  • Elsie Wilsey
    Elsie Wilsey Apr 16, 2016
    Yeah, mine too, how do you get an answer from these people????
I've tried everything, it still doesn't stop the beeping. Anyone else have any suggestions? For those of you who had this problem, did you get fixed? How? Please help!
Posted on Jul 05, 2012
  • Elsie Wilsey
    yeah good luck getting an answer!!!
Hold onto the thread that is coming out of the needle, and pull on the top of it (by the spool of thread) to tighten it. Then it should work fint.
Posted on Mar 02, 2008
Same thing with mine. it stops after 8 stitches every time. now if i use it, i will go for 7 stitches, then let off the presser foot, and start again for 7 stitches. i've tried everything.
Posted on Feb 27, 2008
    New Friend:
  • 185 Answers
This error indictaes that the upper thread is broken. If it is not the sensor is telling the computer the thread is broken. Try tightening the upper thread tension some and rethread the upper thread.
Posted on Feb 26, 2008
My singer ce-100 is giving a error, check lower thread or bobbin. red light blinks and the arm on the ebroidery wont move...help?
is it possible that there could be some lint or loose threads in the bobbin
area?
have you tried turning the machine off & on again to see if it clears the
error?
Apr 06, 2012 | Singer CE-100 Futura Computerized Sewing...
When Sewing a straight stitch machine stops
rethread the top thread, it thinks the thread broke.
Mar 18, 2009 | Singer CE-200 Quantum Futura Computerized...
Dear Nancy,
If you do not get any error message, and the proble does not depends on your procedure ( eg, you left straight stiches plate mounted, or check that is not set width to zero for the straight stitch etc. ) Then a serviceman need to reset the machine from a jumper on mainboard, or reinstalling firmware image.
If you are not in a hurry, you can also try posting the question on this website.
If is not a simple solution problem, and the machine is new , the best thing to do is calling service, as suggested by the Singer manual.
Regards
Apr 13, 2008 | Singer CE-100 Futura Computerized Sewing...
Flashing lights
This is a copy of the post on your premium solution thread.
According to Singer guidelines , if there is only red blinking light, then there is an fault inside the machine, unless it reset disconnecting from power.
If there is an error code with format EM-01 - EM-09 tell me which error you get and I should find a fix.
Here is a complete user guide, check pages 90-92 for common errors.
If you have no error message, and light does not go out with power disconnect then it may be a faulty control board.
In this case I suggest doing a last attempt removing all threads, and reset design unplug from power 10/15 mins.
Let me know if you still have the problem.
Regards
Apr 12, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer ce-100 futura
Hi justmewynn, The url I am adding to this post may be of help. It is a pdf file from Singer contain many diagrams of the CE-100. Maybe you cqan page through it and find what your looking for. Hope this helps you. http://www.futura-support.com/files/CE100-Eng_Fre_Spa-77153.pdf
Sep 27, 2007 | Singer CE-100 Futura Computerized Sewing...
Straight sewing but only a few stitches before stopping
Hi Gaden....It's obvious by your post that you have advanced knowledge in sewing/machines including maintenance, so I feel very confident that your issue can be resolved by updating your software. Please click on the URL below, and download the approriate updates that correspond with your equipment.......Please update your post so I'm aware of your status....good luck my friend http://futura-support.com/downloads/patch.htm
Aug 02, 2007 | Singer CE-200 Quantum Futura Computerized...
Machine stopping
Whenever mine does that, I just press start (the green or red button) on the machine again and mine usually starts back up.
Jun 26, 2007 | Singer CE-100 Futura Computerized Sewing...
Beeping
I have had the same problem with my machine as well. have you tryed, keeping it hooked to your computer while sewing, even if you are not using your embroidery unit it still needs to be hooked up, that seems to have helped some with the beeping.
Feb 10, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
421 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
