Question about Dryers
Squeeling while drying
My dryer makes a loud squeeling noise while drying
    President:
  • 497 Answers
Worn belt, needs replacing
Posted on Oct 07, 2009
Maytag dryer makes loud squeeling noise when it gets hot. Drys clothes but makes such a loud squeeling noise. Have to let it cool down to continue to dry.
Hi and welcome to FixYa, I am Kelly.
A loud squeal is usually caused by either an idler pulley bearing. a drum roller bearing or a loose belt.
Since you did not include a model number I have to respond with generic across the board information. Idler pulleys, drum rollers and belts for Maytags can be found on this link:
(Just past half way down the page) http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drive+Belts+Idler+Pulleys+and+Support+Rollers/default.aspx
You can enter your model number on this page and find your parts: (Choose model number)
http://www.appliancepartspros.com
If you do repair it yourself.... do yourself a HUGE favor and either take a picture of the belt routing or draw a belt routing diagram BEFORE dis-assembly.
Thanks for choosing FixYa,
Kelly
Jun 08, 2011 | Maytag Dryers
Dryer makes loud squeeling noises when running.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 02, 2011 | Dryers
Loud squeeling noise. Sounds like a bearing.
heatman101
Asker
Nov 20, 2010 | LG DLG5988 Gas Dryer
FPaykel Dryer model # DE05US2 is making a screeching LOUD sound ... still turns and dries just VERY VERY LOUD and high pitched squeeling
It could be bearing or guides in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 27, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My Whirlpool Duet dryer is making a loud squeeling noise when drying.
Hello, the squelling noise from your dryer may be coming from the drum rollers. May need to be opened up and lubed. It can also be the idler pulley, also can be lubed. Disconnect power, remove lower panel, and see if you can isolate the noise. Oil where necessary. If you can't get to it, the drum wil need to be removed. If something is locked up or damaged, it will need to be replaced. Caution: Don't stick fingers near moving parts when running :-> Hope this helps, Rich
Jul 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Very Loud Dryer
squeeling hi pitch is usually the drum support roller above the heater. if you take the machine apart and turn all moving parts by hand you should be able to find the problem...if its a rumbling noise then it may be the blower wheel. UNPLUG FIRST..good luck :)
Jun 13, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer making horrible squeeling noise
this is normally a problem with rollers that have gotten dry bearings , take the drum out check the rollers if they turn hard or act sticky you may clean them up and and oil with turbine oil , do not use wd-40 or 3in 1 as these will dry the bearing, check the idler pulley while you have this apart also oiling it if need be
Dec 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer help
Pop the top and get the front off. Get the ball of lint out the blower housing and replace the bad blower wheel.e00d80d.jpg30eaeb0.jpg
Dec 16, 2008 | Dryers
Maytag Dryer squeeling
Drum support rollers. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is making a loud squeeling noise when running
This is probably the drive belt slipping on the drum or motor. There is usually no adjustment on these and it is a case of replacing the belt. If you take the top off the machine, you may be able to look inside while it is running (KEEP CLEAR OF THE ELECTRICS AND DO NOT DELVE INSIDE WHILE THE MACHINE IS IN THIS STATE!) and see the belt slipping. If it is, it's probably time for a new belt
Nov 20, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Dryers Logo
143 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
