Replaced the psu on a sony vaio pcv-54rg the board gets power due to light coming on, but will not start when i push the button to start the computer. put the old psu back in and the unit will start up just fine, when i hit the start switch. what is the deal with the new psu??why won't the new one work in it, it gets power, but the switch(on the front of the sony for on and off) doesn't seem to work with the new psu, but it does for the old one. any ideas on what may be wrong??
  • Christopher Pyles
    Christopher Pyles May 11, 2010
    What models are the old and new psu. Is the new psu New as in New out of the box or new as in new to you?
  • Jay
    Jay May 11, 2010
    do you have the same exact kind of PSU installed? Does it even have the same pins and wattage? That could be causing your problem. Why do you have to replace the old PSU when you said that it powers on your computer?
  • 1,165 Answers
Not the correct psu not enough power being supplied or possibly to much power got a volt meter and do you know how to properly use on.
Posted on Oct 07, 2009
PCV-2200
Remove the PSU use the Model number to "Google" a replacement. You can use more watts, but stay with the same type and output power specs. This may help: http://www.docs.sony.com/release/PCVRS100_SR.pdf ALSO, take a look at Sony Support: http://esupport.sony.com/perl/select-system.pl?PRODTYPE=1
Feb 22, 2013 | Computers & Internet
I want to upgrade the mother board in my Vaio PCV-RZ44G Desktop so that I can run Windows 8. What board forms are compatible and is an Intel I3 or I5 CPU better?
You would be better off applying the money to a new computer. You are opening "Pandora's Box" . You will end up with a old case with ALL new components. That may or may not work, A.K.A., "pain and heartache".
Jan 07, 2013 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Sony VAIO PCV-RS320 PC Desktop Logo Sony VAIO PCV-RS320 PC Desktop will not stay on lpower comes on then shuts off
Well you have a bad power supply then and we have a contract with tigerdirect.We can get you a replacement for under $50.Visit us at
http://www.ezsystemrepairs.com/ .
Jul 01, 2012 | Sony VAIO PCV-RS320 PC Desktop
Power cable at rear of sony vaio pcv desktop sparking and not starting up
Stop using it. Bring it to a repair shop ASAP. You need your PSU replaced and if you keep using it you'll need your motherboard replaced as well. In fact if you keep using it you could burn all of your internal components out.
Jun 09, 2012 | Sony VAIO PCV-V200G PC Desktop
When I turn off the cpu with the windows shut down or sleep or power button it will only return when you toggle the power to the psu on and off, When you push the power button to restart or start up the...
Very similar problem
1. Is there a GREEN blinking light on the motherboard?
2. Check you BIOS setting. These motherboards have software installed to check voltage readings to and from the motherboard.
Apr 03, 2011 | Sony VAIO RB30C (VGCRB30) PC Desktop
PCV-W510G Power Supply Issue
Will Sony sell you another PSU?
It's a laptop I'll bet they require you to get authorization and return for service. Do so.
Best Regards
sonofspy
Jan 02, 2009 | Sony VAIO PCV-W510G PC Desktop
VAIO PCV-W600G DESKTOP
Try unplugging components one by one (disk drive power, CD power, video cards, etc) with the system unplugged and see if the fan speeds up when you restart it. Note than when you remove certain cards, video for example, you may get beep codes.
Everything in a slot on your PC shares a common power bus so any card installed may be pulling too much load on your power supply. Pull em one by one re-starting between each one.
If this doesn't locate the fault, check the power plugs to your disk/cd drives and ensure that you are getting 12VDC between the yellow and black wires and 5VDC between the red and black wires.  If you are not, and you have already pulled all cards/drives, you have either a defective power supply or your motherboard is drawing too much current.  In the last case, pull your memory cards one by one and re-start between each pull.
YOu will get memory size errors if you let the boot procedure go too far but all you want is for the fan to go.
You  can accurately pinpoint POST errors with a POST diagnostics board available at most PC shops. It comes with a code manual.
Oct 15, 2007 | Sony VAIO PCV-W600G PC Desktop
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
