Question about Dell Studio 1535 Notebook
I forgot my password I can't start windows 'cos the pass word
    President:
  • 2,600 Answers
System (BIOS) Password Reset
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
Posted on Oct 07, 2009
How do i factory reset my desktop i forgot password
If you forgot your Bios password then open the pc and reset the COS jumper.
If forgot your Windows password then restart your computer press F8 . select Safe Mode and try administrative login to reset password.
If you forgot the administrator password then use any third party software like Hirenboot to recover it.
May 15, 2014 | eMachines ET183105 PC Desktop
Asking for password before system. Boots
Maybe you forgot the pass or some users put pass on your system or account..You can salvage your old user account by logging on as the "Administrator" user. Once you're logged in as the admin, you can reset your old user password. The Administrator user (by default) is similar to a "superuser" and has the highest access level to reset any user password.
If you don't know what your Administrator password is, you can reset that by rebooting into Safe Mode.
The best option here is to reset your account password. You can do this using either 1 of the 2 methods suggested by Microsoft Knowledge Base article #321305. In my opinion, the second method described on this page is most likely the easiest route: Reboot Windows in Safe Mode. Click Start, and then click Run. In the Open box, type the following command, and then click OK: control userpasswords2 Click the user account that you forgot the password for, and then click Reset Password. Type a new password in both the New password and the Confirm new password boxes, and then click OK.
Side note: To access Safe Mode, Click Start -> Shutdown (or Turn Off), and choose 'Restart'. Once the computer restarts, press F8 repeatedly on the keyboard until a Boot Menu appear (this *must* be done before the Windows boot screen appears). Finally, choose to boot Windows in Safe Mode and press Enter on the keyboard.
You can reset a lost or "forgot Windows password" with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like "Windows Password Breaker".
4. Re-install. Will lose data.
goodluck and hope this helps.pls rate ..thanks
Feb 21, 2011 | Intel Computers & Internet
Need two mannally reset password for my dell inspiron-1520 laptop cos i forgot mine.
You can use Hiren's Boot CD: http://www.hiren.info/pages/bootcd Go down to Password Tools and choose either one of the following: Password Renew 1.1, NTPWD, WinKeyFinder 1.73, Offline NT Password Changer 2010-06-27).
Nov 19, 2010 | Microsoft Windows Vista Home Premium with...
Forgot password
if this is a windows password the easiest way (if you didnt change the admin pass) is to start the comp pressing f8 then start in safe mode..log on as administrator and remove pass through control panel - users
Jul 10, 2010 | Acer Aspire One Netbook 8.9" Notebook
How do i get passed my hdd user password i forgot the password
A couple of days ago, I lost my windows vista admin password. I solved the problem with the help of Windows Password Seeker. Not just support XP/Vista/2000/NT, but also compatible with windows 7, I tested it on my computer installed with Windows 7 and remove the local user and admin accounts password successfully. It's worth trying. You can download it from: http://www.passwordseeker.com/howtouse.html
May 19, 2010 | Toshiba Satellite A205-S4617 Notebook
I FORGOT MY SECRET QUESTION TO RESET MY NEW PASSWORD
Power on password or login password?
To reset
1 Power on pass-call and go to HP Service Centre (better with proof of purchase) or to laptop repairman.
2 Login pass to OS - use EDR Commander and put new one
Good luck
Sep 11, 2009 | HP Pavilion DV7-1020US Laptop
Forgot my password
When you start the computer hold the "F8" key to activate "safemode". Then start up Windows and look in the control panel/users and change the password.
Jun 09, 2009 | ASUS Eee PC 2G Surf Notebook
Can't get passed micron electronics screen.
is ur password displayed during startup (POST) or in windows ? if it is display during POST, remove the CMOS battery for while and back on. And if it is in windows, start the computer in safe mode (by pressing F8 key during startup) and change the logon password. hope it works.
May 03, 2009 | Computers & Internet
Fogot the password and a questions
in login page their forget pass word option is their. enter your date of birth and your gender and further question answer then only it accepts to be logind
Apr 29, 2009 | Yahoo Messenger
Forgot my password
I can reset the security eeprom. 30bucks you pay shipping.
geokohler at gmail.com
Jul 15, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Dell Studio 1535 Notebook Logo
345 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
