HI. The start switch is the culprit in this situation. you must replace the switch asap. The replacement of the switch will correct this issue. The switch circuit is weak, and not able to maintain a closed circuit.
Comments:
Oct 07, 2009
- This is a fairly moderate repair procedure, and if you have the right tools and technical savvy, this can be attempted by a novice tech. I do not recommend a do it yourself if you are not at least a novice tech.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
Thank you so much! We will order the switch and fix it ourselves (and save about $150)!
" - dmath0728
Popular Solutions for GE DBXR463EBWW / DBXR463EBCC
Hoover tumble dryer cut out before time was up. When tried to restart just makes a noise, drum...
(More)
Hoover tumble dryer cut out before time was up. When tried to restart just makes a noise, drum doesn't rotate and smells as if something is burning.
When I turn the start bswitch to the start position the dryer starts. When I release the switch the...
(More)
When I turn the start bswitch to the start position the dryer starts. When I release the switch the dryer stops. Is this the switch itself or how can I check? Thanks
