Question about Peavey Music
While using my xr684 for practice at home,there was a loud noise and a smell of burning electic circuit,so I turned off.a friend who used to work in the amplifier business looked at it for me and said it would be too expensive to repair,but I can still use as a mono amp(the whole row of red lights on the lower EQ are on permanently)Any suggestions for a cause or a cheap, easy,DIY repair PLEASE
  • Peavey Master
  • 5,603 Answers
Probably one of the two amplifiers in it had a failure. It is probably economically repairable by a COMPETENT technician. I would expect several transistors have failed probably $30 if parts maximum.
I would NOT suggest using it with the failure as further damage or even a slight fire hazard might exist.
Bad or intermittent speaker cables are common cause of this type failure. Overdriving or even a bad speaker can also cause it.
Posted on Oct 07, 2009
After hooking up the PA for practice, I heard a loud "pop," then followed by a burn smell, from my Mackie SRM 450 speaker, which I use as a monitor. No sound comes through but static and crackling. Is the...
The pop itself isn't necessarily a bad thing, but a burn smell and the fact that it's only outputting a crackle likely means that the built-in amplifier circuitry has been overloaded. This can happen a few ways:
1) Faulty power, either a bad cord or a bad outlet
2) Plugging the output of a power amplifier into this speaker - because it has a built in amplifier, this speaker only wants a non-powered line input
3) If the Thru output is (accidentally) plugged into anything that provides phantom power, that could overload the circuitry.
4) A short due to liquid or moisture contact - these cabinets are most certainly not waterproof
In any case, the amplifier part of the circuitry IS replaceable. If you're not comfortable buying one and replacing it yourself (I'd recommend eBay), take it to any shop that sells similar items. If you're extremely lucky, it was just a fuse that needs to be replaced, but chances are you'll need to replace the whole amp.
Aug 19, 2013 | Music
Serial number 00-06778552, a gig amp manufactured about 1977/78, (used in an American tour in 1978). While running a practice session at low volume, the yellow DDT light blanked altogether (this has been...
The amp has a failure. One side of the power amp is starting to draw excessive current to the point that the filter caps can't sustain the current so the ripple starts to be heard in the speaker. Continued use MAY burn up the speaker by sending DC through it as well as causing additional damage to circuit boards, etc..
May 25, 2011 | Peavey Max 115 1x15 Bass Combo Amplifier,...
My Marshall mg100hdfx is a little over 2 years old and i never used it that much. I turned it on, made a popping noise and shut down. No smoke but i could smell a slight electrical burn smell. I never...
DO NOT try to use it until it is repaired or you may do further damage. Probably a capacitor shorted or a diode in the power supply. This is NOT DIY unless you are competent at electronic repair. When it is appeared to be restored, put a 150 watt lamp in series with the power cord to limit current till you know it is repaired... saves fuses and destroying further components if there are other parts that are bad.
Nov 03, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
During performance, the monitor channel started giving loud noises and no music anymore. The mains channel was playing normally. 15 minutes later, the unit started giving a burned smell and I switched it...
Likely a failure of one of the amps and now more... You should have shut it down when it started making noises. This is NOT a DIY repair. Take it to a competent repair shop for service.
Oct 11, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
I have a Zoom G2, It has excessive noise. It has the correct power supply and I tried powering it with batteries, but it still produces the loud distorted noise. It worked fine the last time I used it. ...
Check if it might be an intermittent input or output jack by wiggling these. Jackks are notorious for problems. Often the soldering of the jack to the circuit board seperates causing noise.
Sep 27, 2010 | Zoom G2 MultiEffects Guitar Pedal
TRANSISTOR TYPES FOR PEAVEY XR684 MIXER AMPLIFIER/ARRANGEMENT
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
Jun 30, 2009 | Peavey Pv 2600 Power Amplifier
On power up there is a loud humming even with volume at 0
I would also be inclined to check all the larger electrolytic capacitors in the power circuits as well for AC bleed.
Feb 11, 2009 | Yamaha Electric Guitar
Music Logo
158 people viewed this question
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
