Question about HP Pavilion a1120n (PX759AA) PC Desktop
No video out to monitor from desktop.
No video out to monitor. Monitor works fine when connected to my laptop. The monitor is normally connected to a HP Pavillion a1120n desktop.
  • 71 Answers
Sure not hard at all. if the monitor is connected to the default onboard video adapter, this is usually one of the first things to malfunction on a new computer. if the monitor works when connected to another machine, but when connected to the desktop the monitors amber or orange light comes on but no video, this usually means there is a connection problem. usually most modern monitors will display a "no input" or "no video" message meaning the connection to the computer is bad. try getting a new video adapter (usually pci/pcie video card) and installing into the pci/pcie video slot in the back of the computer. most are plug and play and require little to no configuration. you should be able to find a nice one for about $20 - $30 dollars at www.tigerdirect.com . hope this helps. please rate me and thanks for choosing enterprise computing solutions.
Posted on Oct 07, 2009
Need both laptop and monitor on at same time.
Hey Roger,
Below is information that should help you with trying to get monitor and notebook screen to work.
First make sure your laptop is equipped to be able to connect a secondary display, there should be a port for connecting a standard monitor cable on the back.
Connect your secondary monitor and reboot the laptop, the system bios should recognize that a second monitor has been added.
Then right click on your desktop and bring up the display properties dialog box.
Select "settings"
Your laptop should be identified as monitor 1 and you should also be able to see the secondary monitor as monitor 2.
Click on the secondary monitor and check the box that says "Extend my Windows desktop onto this monitor".
Set your screen resolution and color quality for the second monitor and click apply.
Directing icons and browser windows over to the other monitor is just a matter of drag and drop.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 11, 2014 | Dell Latitude D600 Notebook
Why does the Little Green Light on the front of my Monitor just Blink and the Monitor will not come on ?
The monitor is not getting any "signal" from the video-card.
Check that the video-cable is connected to both the monitor and to the video-card.
Try connecting the monitor to a different desktop/laptop,
to see if the monitor works "elsewhere".
Try connecting a different monitor to your desktop, to see if the video-card is the problem.
Sep 18, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Hi,please if you can help me.I have NEC MyltiSync FE 1250 monitor.It stoped working when is connected to desktop,it has light on but the screen is blank.I've connected it to laptop and it works fine but...
You have proved the monitor is OK.
If the desktop appears to boot up then the most likely problem could be a faulty video card OR the video card setting has been changed that is outside the range of the monitor's capabilities, ie, the refresh rate set too high (set it to 85Hz or less) or the screen resolution is set too high (set it to 1024x768).
You may need to connect a different monitor to the desktop to get a display to lower the video settings.
Sep 03, 2010 | NEC MultiSync FE700 17" CRT Monitor
My screen is splitting in 2
Connect the monitor to another (desktop or laptop) computer, to see if the problem "follows" the monitor.
Connect a different monitor to your computer, to see if your computer is sending the "wrong" video-output to your monitor.
Jul 20, 2010 | Acer 22" X223w LCD Monitor
Trying to connect my Samsung NC10 to a monitor
managed to connect to my desktop monitor and all working fine, new screen needed and I'm back to normal!!
Mar 30, 2009 | Samsung NC10-14GW Notebook
How can I
Normally a laptop has an external video output in the form of S-Video, VGA, or HDMI. Once you have connected the laptop to the television through one of the available outputs. You will have to enable the external video out on the laptop. Normally this is done by pressing the FN and a labeled F key. Example: If the laptop was a HP you would press FN + F4 to enable the external monitor. Gateway, eMachines = FN + F4. Dell FN + F8. You will have to look at your keyboard close and look for what looks like a little monitor. That key + FN will most likely be how you enable the external monitor.
Once connected, you use the FN + F4(from example) to cycle through the video modes. The video modes are usually Laptop LCD and external monitor, external monitor only, Laptop LCD only,
If you would like to extend your desktop to the external monitor instead of clone the desktop than you will have to go into your display properties and click on the second monitor and check the box that states "extend the desktop onto this monitor". This will allow you to drag windows from the laptop LCD to the external monitor.
Mar 29, 2009 | Vizio L37 Television
Computer Turns on but nothing on monitor
The monitor detects the presence or absence of synchronization signals so your video (integrated or otherwise) isn't putting out video or sync signals. This could be because the boot isn't happening as it should or just a bad video installation.
Dec 22, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Insignia D400a
Get a video card that matches your motherboard and your problems will be fixed
Dec 18, 2008 | Insignia D400a PC Desktop
I get pink spots on my laptop
This is known as bleeding in LCD .you can try to update video drivers or try to connect external monitor (any normal desktop monitor) and see if same thing happens on external monitor then most probably it is the video card if on external monitor works fine then it is issue with LCD .if system is in warranty then get in touch with dell support
Let me know if this helps
Regards
Sep 14, 2008 | Dell Inspiron 1501 Notebook
Dell Laditude monitor stopped working.
yes, it sounds like somehow the back light behind the LCD has gone out, cheaper to replace the whole LCD then to replace the light itself, but do connect a desktop monitor to it before you go out and buy one, if it works fine then you know its the lcd, if it does not work then it may be the internal video card.
Jan 02, 2008 | Computers & Internet
HP Pavilion a1120n (PX759AA) PC Desktop Logo
158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
