Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
How do you install starter rope on 1979 model mercury 9.8 outboard motor. from the factory end of pull rope has a pin thru it that inserts in a slot instead of a knot, so what position does this pin fit in slot-- i didn't have original pin using a needle bearing about an inch long hope this works. thax j zakos.
2 Suggested Answers
muffteck
  • 202 Answers
SOURCE: Need a operation manual for a 1975 Mercury 9.8hp
put it in a water barrel and start ck compression ck for bent prop shaft and water in gear case b/4 u buy
Posted on Nov 11, 2011
1974 40H.P. mercury outboard been setting up for 10to12yrs
This is probably a Merc 400 and you can remove the upper cowling and rope start it if you do not have the rope starter already attached. As I recall, all of this class motor were manual start with optional electric start, so thy came equipped with pull starters.
If the motor will not turn over manually then it is likely seized or frozen up and requires professional help. I have worked on numerous Mercs from 5 to over 100 HP and every one would turn over by pull starting if they were mechanically sound.
Apr 10, 2014 | Clymer Mercury 3.5-40 HP Outboards...
Replacing starter pull cord on 77 20hp mercury
Remove the starter housing from the top of the motor and see if the spring broke or back wound it's self when the rope broke. If all is well remove the rest of the rope from the spool by feeding it back thru the guide hole the handle rests on. Wind it out and find a hole drilled thru the spool and put a punch thru it to lock the spool in place against the spring pressure. Remove the old cord. If it has a steel hook glued to the anchor end you will need a real mercury part. If it has a knot. your in luck.
Take your new cord and burn one end and roll the cord to a point while it is still molten. Tie your knot and heat it till it is cooked so it won't untie itself. Feed the pointy end thru the spool and out the front of the housing. Tie a knot it it where the handle would go. Gently feed the rope on to the spool when you remove the punch.
You will have more rope than the spring could wind. so untie the end knot and feed it back to the spool and put the cord in the notch of the spool so it won't rub on the housing and wind a few more turns into the spring .
When it has enough pressure to completely wind the cord up. put the punch back in the lock hole and feed the cord out the hole thru the handle and knot it, then cook that knot as well.
Sep 16, 2012 | Boating
15 hp crysler outboard motor pull start diagram
You will need a special tool to do that job. It is just a 10/24 long bolt bent to form a crank and a nut spun on it and soldered or double nutted to keep it in place.
Remove the top slotted bolt and replace it with the tool.
Release the pressure on the cross pin by back winding the spring- and remove the cross pin.
The starter gear will slide up the shaft after you remove the flywheel. Or you can loosen the 2 screws on the top bracket.
Now release the tension on the spring and pull the core from the spool.
The spool comes out and the rope must be freed from the guide.
The reverse is about the same- feed the cord and spool it up attach the handle.
Replace the top bracket if you removed it. Put on the starter gear
grease the spring with light grease inspect the nylon base and coil anchor (tiny brass cinch squeezed on to the stub of spring coming from the base.
Now -with the tool- wind the spring backward about 5 times and insert the pin thru the gear and into the shaft. With the tool in place pull the starter thru several times to see if the tension is right and you didn't forget the rope guide..
Replace the original screw to hold the pin in place.
This works for most pop-up starters.
Oct 20, 2011 | Light Outboard Motor Boat Bass Fishing...
DO I NEED SPECIAL TOOL TO REFIT COIL SPRING WHICH CAME OUT WHEN FITTING STARTER PULL CORD
There are special tools made for this job, however not needed for most jobs (makes easier). Clean the spring and lube slightly with silicone spray or light oil. Catch the end of the spring that would be the outer end onto slot or pin and slowly spiral the coil into place holding down coils as you turn(dont try to coil the spring then drop it in, take your time as you wind and maybe ask a freind to lend a third hand if your fingers get tired, once you start you cant stop). The inner part of the coil has a bent hook that will catch on the inner portion of the pull rewind. Lood at how the rewind catches this hook by turning the rewind in the direction that it turns when you pull the rope. When you pull the rope it winds the spring. If you put the spring in backwards the rewind spring will not catch. Once you got the spring in place, turn the rewind in the direction that it turns when you pull the rope until it stops, then release one turn and insert rope thru guide and into spool to tie knot. Slowly let rewing pull in new rope. Good luck
Aug 23, 2011 | Electrical Supplies
Rope on Craftsman Convertible weedeater wont rewind.
Remove the tube that holds the flex-drive shaft from the front of the motor cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, ou will have to lock up the engine. Remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or something so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place. Reassemble and you are done. Disassembly requires Torx head drivers ranging from T-15 to T-25. Here are more details involving the starter/recoil assembly.
With the starter/recoil unit OFF the machine, with no rope in it, and no tension on it.....grasp the little nylon hub and turn it (clockwise is I recall) round and round 6-7 times until you feel the recoil spring get nice and tight...DO NOT LET GO OF IT!...hold it in place and then JAM the starter/recoil unit in place (still tight) inside it's housing by either clamping it with a tool like vise grips or by sticking a screwdriver thru it and thru the vents in the cover. If you have ANOTHER person to help you...one of you hold it in place....and make sure it is lined up to where you can NOW insert the new lenth of pull rope. Always use new rope....Feed the end thru the hole in the recoil unit and tie it off, by wrapping it around itself outside the nylon hub and then screw the little self-tapping set screw back in holding the rope down. OK...then feed the opposite end into the hole in the front engine cover and attatch the T pull handle....Now mind you, you are still jammming or holding the recoil in place against the spring!...Now, unclamp it or unjam it and slowly let the recoil pull the NEW rope you just installed back onto the pulley. Make sure it is fastened well on top of the pulley around the nylon hub and also fastened well onto the T pull handle. That is it. Then reconnect your wires, put your throttle cable back thru the engine cover and reinstall the Torx screws in the cover.
May 27, 2011 | Craftsman Convertible 14" Gas Line Trimmer
Out on boat when starter motor on mercury 70hp 3cylinder stopped working.back on shore took it off and put it back on.when turning enine over starter seeems to spin in wrong direction and not spinning up...
Spin Backward? that's not good. Would check the battery connections. If backward- you may have other problems associated with backward battery connections and ignition systems. If it's just an optical illusion- you should try to bridge the starter solenoid with a jumper to the big terminals and see if the starter is really bad or just a low battery. If your battery is down, your charge system on the motor may be giving you trouble.
Your starter when sitting on the bench and directly hit with 12 volts should jump substantially with the torque. If it just spins like a fan motor- it's shot.
If jumping the solenoid makes it work, thats the problem. But clean or replace the cable ends on the bat and solenoid first.
Just a note: you should be able to pull start that motor by wrapping a noted rope round the pulley on top of the flywheel. If you ever get stuck again. Just watch where the knotted end of the rope goes.
May 03, 2011 | Mercury Mark 30 Hipo Outboard Motor...
I have an MTD Snow Thrower Model 2M1 with a broken starter rope. I replaced the rope but cannot get it to rewind the rope after I pull it. What am I missing when I reinstall the rope and spool?
When you have the starter top removed, you must wind the spring BEFORE installing the rope. Wind the pulley until it is at maximum tension, then unwind it until the hole in the pulley lines up with the eyelet on the starter top. Now, put the rope thru the eyelet and into the pulley hole. It is helpful to have somebody holding the tension on the pulley, or you can insert a small tool thru the vent holes to hold the pulley in place. Use a figure 8 knot on the rope. Go ahead and tie the handle onto the other end of the rope, and release the pulley tension. It should now recoil into the starter housing. Test pull the rope several times to make sure it is moving freely. Reinstall the starter housing onto the engine and retest.
Dec 01, 2010 | Mtd Products Yard Machines 158CC Tiller
Starter rope pulley will not pull the rope back into the leaf blower.
Most commonly, the recoil rope rewind spring is broken. However, inspect the recoil housing assembly first to make sure no debris or rope fragments have prevented the rope rotor from rewinding. Always remove the spring 'AS A LAST RESORT'. Many rewind problems can be solved by inspection of the rotor and not have to remove the spring. In case you do, I will include instructions on how to re-install.
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Nov 21, 2009 | Craftsman Garden
STEP BY STEP DIRECTION. REPLACE STARTER ROPE. MIGHTYLITE BLOWER MODEL #UT08520
Nov 14, 2009 | Garden
Evinrude outboard motor starter rope
most likly is missing a washer,has been reassembled incorrectly.take apart and check
May 06, 2009 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
177 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
