Question about KitchenAid KAWS850L Top Load Washer
KitchenAid KAWS850JQ will not drain or spin. I emptied all water and clothes and found lots of lint material from a rug. I cleaned material from inlet and outlet of pump and from drain at bottem rear of machine. Agitator still functions. Still no functions at all for spin/drain function. If the pump is bad why doesn't the spin work? If the pump is jammed on the inside can it be opened and cleaned?
3 Suggested Answers
  • 708 Answers
SOURCE: My KAWS850J does not drain or spin, probably due to clogging.
you would have to pull the back off of the unit to gain access. The drain wont be clogged, it is most likely the pump. what probably happened was material from the rug got sucked into the pump and wrapped around the fan that pushes the water out of the washer.good luck
Posted on Oct 06, 2009
rickyrt441
  • 4399 Answers
SOURCE: KAWS677EQ0 washing machine.KitchenAid. It Wont
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
Posted on May 02, 2011
Frigidaire front load washer. water is not draining out during spin cycle leaving the clothes clean but sopping wet.
It sounds like either your drain hose is clogged or the water pump is inop. If you have washed any rugs or material the may come off and clog the pump that could be the problem.
You can remove the lower front cover ( 2 screws I think) and follow the black rubber hose to where the pump is located on the lower right side when facing the washer. The hose has a spring clamp you can remove if necessary to clean the hose.
Remember to unplug the washer when working on it.
Aug 09, 2010 | Frigidaire ATF6000ES Front Load Washer
My washing machine will not spin the water out of my clothes,what is the problem?
Have you washed any rugs lately that may have shed some material? Is it making any unusual noises? Is there any standing water in the drum?
Not sure what type of machine you have but it sounds like the pump inlet is either clogged or the pump is inop. With a little more information we may be able to narrow it down.
Jul 23, 2010 | Frigidaire ATF6000ES Front Load Washer
Stopped spinning from heavy rug
what is error, most likely plugged the pump
Apr 18, 2010 | Frigidaire Affinity ATF7000E Front Load...
Oct 06, 2009 | KitchenAid KAWS850L Top Load Washer
Lint from my washer keeps clogging up my drains!
there are mesh screen lint traps that attach to the end of the drain hose.
Check Home Depot or Lowe's.
Jul 24, 2009 | Washing Machines
Frigidaire affinity not draining
The problem is that on the infeed side of the pump there is a catch/filter in the Hose/boot that will catch lint and coins (LOTS OF COINS) and will not allow the water to flow through to the pump. This will stop the cycle and prevent the tub from spinning and the basin will not drain.
to fix this turn your washer over and access the pump from the bottom. the boot can be disconnected from the wash basin with a phillips screwdriver, reach in the boot and pull out the plastic catch and empty the debri, reinstall the the catch after cleaning it and put the boot back on. Set your machine back upright and conncet all the hoses and plug it in. It should work. This is a easy job but it will take an hour or so.
Sep 20, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Water will not drain on the spin cycle
sump'n peer's ta be stuck all down up n thar."--- thers an answer id go with..
backing to the rug ir perhaps the tassle ends have problaby clooged the pump assy preventing water from draining, i couldn't look up schematic firyou , themodel number was not found at sears website, but yea, defff sounds like there "sump'n peer's ta be stuck all down" the pump will hav a ghose leading to it, yuou should be able to flsh out the debris cant see needing to replace the pump
Apr 02, 2008 | Kenmore 98702 Stacked Washer/Dryer
Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Nov 20, 2007 | Avanti Top Load Washer W797
HELP my washer won't empty or spin!!!!!!
1) there are three philips screws on the bottom front of the washer.  After you remove the screws, the front metal panel will come off.
2) Under the panel, there is a circular plastic filter.  This unscrews by hand - but wait!
3) I put a 9/13 cake pan in front of the filter on the floor to catch the water that will come out as you unscrew it.  The pan will fill several times, so plan on emptying it as you go along.  You can also get a second person to hold the washer on a tilt so that it doesn't drain out at all.
4) You can pull the filter all the way out and clean it.  I found change, a pen, and a lot of lint.
5) put the filter back in and run a rinse / spin cycle to clean it out.
6) you may have to repeat this multiple times if it is badly clogged, but it will solve the problem.
Nov 08, 2007 | GE Energy Star WCVH6260F Front Load Washer
Lg Front loading washing machine
most times on the Lg washer the lint trap is clogged and something may be hitting the impeller on the pump and causing it not to drain. remove the plastic cover on the lower left bottom and unscrew the black lint filter at the pump. you will get water on the floor there is no way to avoid that. clean the trap and make sure there is nothing inside the housing to block the pump impeller. replace the trap and run a rince cycle to check for proper draining.
Aug 04, 2007 | LG WD-1080FD Front Load Washer
KitchenAid KAWS850L Top Load Washer Logo
130 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
