Question about Jensen VM9510 Car DVD Player
Dvd player on Jenson VM9311TS
I have had my Jenson VM9311TS professionally installed. He hooked it up to a toggle switch to bypass the blue screen safety screen. When I try to play a dvd it will not work. The display says that I have traveled outside of the US roaming area as if it is on navigational mode. I have tried several dvd's with no luck. Any suggestions?
  • john louis Dec 24, 2007
    yes. take it back to him so he can do it correct.your navigational cd might not be in the wrong cd drive.
Well if u haven't fixed it yet this is what u do. now that u have the toggle switch and that blue screen is gone ,now u put that code in . u put a dvd in when it starts u press stop twice on the remote then press1264 . as soon as u put in that last number a menu will appear on the screen that says
this what u should have it at if not then change it to this
REGION:1
BRAKE OVERRIDE: ON
MACROVISION: OFF
Posted on Mar 23, 2008
Bypass parking break feature on the Jensen VM9311TS
You can purchase an aftermarket bypass kit from electronics store or off ebay... But hey, be careful, no watching movies while driving... K
Jun 05, 2009 | Jensen's VM9312 Car DVD Player
Jenson VM9311TS will not play all speakers in cd mode
YES!! You used the blue wire to turn on factory amp (blue wire to GM pink) you NEED to use the Blue/White wire. That is the amp turn on. The blue wire goes dead when you play a CD or DVD because it's for a power antenna. So, Blue/White ok?
Enjoy,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 22, 2009 | Jensen VM9510 Car DVD Player
Need bypass code for Jensen VM9311TS
Here it is how brother,insert a dvd movie,next use the toggle switch sequence to get image,next press stop button twice on the remote,then press 1 2 6 4 on the remote,you will now see a menu that says
Regon Code
Brake Override(I know you are drooling by now)
Macrovision
Loader Version
Model Version
Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle on,off or which region code you want.
This wht you want.
Region Code 1
Brake Override ON
Macrovision OFF
When you are done,click SYS SETUP on the main remote TWICE to save the settings and vingo.
Nov 22, 2008 | Jensen VM9510 Car DVD Player
BackGorund Change on a Jensen VM9311TS In-Dash DVD player
There is no e-brake override code. You have to hardwire it to bypass the e-brake. Take the peach-colored wire and ground it to metal inside the dash. Put a toggle switch inline on the wire and mount it somewhere you can reach it. When you get the blue screen when starting a movie, open the switch for 3-5 seconds, then close it again to reapply the ground. Your movie will start up, and you can then drive away with it playing.
Sep 24, 2008 | Car Audio & Video
DVD player playing while driving
It's not that difficult. Get a two position toggle switch and run the wire that normally goes to the brake, into one end of the toggle. Then run a wire from the other end of the toggle to a ground. Whenever the message comes up on the screen about viewing while driving, flip the toggle switch on then off and it will bypass the safety feature. That's how I did mine and two other buddies of mine.
Aug 07, 2008 | Pioneer AVH-P5700DVD Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
you need 2 toggle switches . yello/blue wire to switch - switch to ground.
yellow/black wire to switch- switch to red ing. wire. turn this switch on and pulse the other(yellow,blue) 3 times and leave on, then turn the other switch off and then you can ride and watch dvd. just did it this morn. QTRHRS
Feb 24, 2008 | Alpine IVA-D310 Car DVD Player
hook the pink wire to a toggle switch and ground the switch to the chassis. when the unlawfull screen comes on then turn the switch on for a few seconds then back off for a few seconds then back on and the screen should go away. I done this with mine and it works. unfortunately you have to do this every time.
Feb 23, 2008 | Audiovox VM9311TS
CAN U HELP ME?
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
Dec 27, 2007 | Audiovox VM9311TS
JENSON vm9312 Video Bypass
check this out man, go to fm/am mode. with the remote hit the setup botton. then enter 543210 and be sure it beeps on every diget. then hit the hammer/screwdriver icon and turn the parking brake "on"
Oct 09, 2007 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
Jensen VM9510 Car DVD Player Logo
285 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
