Question about E-Machines 6809 Notebook
Machine shutsdown hard shortly after boot
Machine shuts down hard shortly after boot up.........removed battery, and rebooted but same results
External power supply seems fine and notebook power indicator light illuminates while computer is plugged in.
Notebook seems to run on battery power fine.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 201 Answers
OK, i experience this before, i think your situation is mostly like mine, and this problem may cause by the your laptop power adapter, please replace a new adapter and see how is the result. Hope this help.
YBC (/\)
Posted on Oct 07, 2009
Vaio wont find wireless stick
Remove the USB, shut down, unplug, remove battery, plug in, reboot, when fully booted insert USB. Post results. We need the Sony Model and the OS you are using. The Wireless device(stick), make and model.
Mar 02, 2013 | Sony VAIO Computers & Internet
Sir, I have Lenovo G580 model Name 20157 Laptop Windows 7 Ultimate and 2.5 GHz 4GB RAM I intall Nvidia_VGA_Driver_8.17.12.9673(N13M-GE7) Win7 64bit Software and i copied the Nvidia Drivers files folde
Remove ALL media, DVD, CD, USB, Shut down, unplug, remove battery, leave battery out, plug in, reboot, post results, give details. Will the laptop boot to safe mode?
Feb 23, 2013 | Computers & Internet
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Thinkpad R51 will not boot
Try remove ALL media DVD.CD,USB,etc. Shut down, unplug, remove battery, plug in, reboot. Do you get anything on the monitor? Can you access the restore/recovery software? Open the Memory bay and reseat the Memory, open the HDD bay reseat the HDD, Reboot. If no change remove HDD, test, replace if necessary. Have you changed the CMOS battery?,
Jan 18, 2013 | IBM ThinkPad R51 Notebook
Media test failure message. Reboot and Select proper boot device
A hard disk failure can be catastrophic if it jeopardizes the data stored on your computer.
In addition to rendering a laptop inoperable, a failed hard disk can damage other files stored on the drive as well.
It is critical to determine whether an actual drive failure has taken place, and there are several steps to troubleshoot a drive before hard disk failure can be declared.
Unplug any devices such as printers, speakers, cameras and other external peripherals. Boot the laptop by pressing the power key.
If this does not result in a successful boot, try booting Windows in "Safe Mode."
Reboot the computer, and hold down the F8 key this will vary depending on your computer and operating system
From the menu choices, choose "Boot Windows in Safe Mode".
If the boot up progresses, then the computer is likely experiencing a software issue, not a hard drive failure.
Reset the hard drive.
This will involve turning off laptop (removing the battery is a good move, too) opening the laptop unit, and unplugging all connections and cables from the hard drive.
If possible, replace the hard drive with another drive.
This will help determine if the hard drive is causing the problem.
Plug all connections back in to the hard drive, and reboot the computer.
Repeat Step 2 if necessary.
If the computer does not reboot, the laptop is more than likely experiencing a hard drive failure and will probably have to be repaired by vendor.
hope this helps
Oct 09, 2012 | mpc X3000 Laptop Transport 14.1" Barebone
Toshiba A105-S4104 laptop restarts shortly after powering on. Replaced memory same issue, upgraded OS to Win 7 Pro by using another Toshiba laptop it works there with no problem. Put in A105 starts but...
If it completes the power on self test and reboots when starting windows, you are getting a BSOD, If you have a recovery disk or recovery partition on the hard drive, try a repair install of windows 7.
You are getting the BSOD because the hardware between the two laptops are different. Windows is looking for one thing and receiving an unexpected result. A repair install using the hardware windows will be running on will fix the problem
Apr 06, 2011 | Toshiba Computers & Internet
My pc shut down on me now we cant reboot it it say there is no hard drive
well is dead hd (normaly the final step of virus spreading), must be replaced.
Jan 16, 2010 | E-Machines eMachines Desktop PC
Dell Dimension 4600 will not reboot. I have to turn it off, unplug the power, push the On/off switch for a moment, let it set for 15 min then it will reboot. I have recently upgraded from 256kb ram to 1gb,...
from what you describe, they system will not shutdown. So try the following:
  1. Boot to safe mode (F8 at boot) and then see if the system will reboot from the safe mode.
  2. Boot to the Safe Mode again, Start RUN MSCONFIG, edit the startup group, (Basically uncheck all the items in the startup tab) reboot in the normal mode then see if it shutsdown. If it shutsdown normally, then start adding items back one at a time until you identify the items that were causing the items.
Jan 12, 2010 | Dell Dimension 4600 PC Desktop
E-Machines 6809 Notebook Logo
117 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
