Question about Dell 4100MP Multimedia Projector
Is there an adjustment to the lens either physically or through the projector menu that will center the image in the lens?
    Problem Solver:
  • 8 Answers
The image should be centered automatically. What input is being used?
Posted on Oct 07, 2009
I have problem with christie projector roadster x9
If your's is the "s" model there is no keystone adjustment provided. Otherwise the keystone adjustment is found under MENU then 1, Size and Position and under MENU 2, Image Settings. Also, refer to this excerpt from the manual:
NOTE: This function is not available in "S" models.
Adjust the keystone control if images appears non-rectangular or keystoned in shape-that is, smaller at either the top or bottom edge. The effect of keystone adjustment is similar to
physically tilting the projector forward or backward in relation to the screen, and it affects all sources.
NOTES: 1) Keystone is enabled for a source only if Size is 1000 and Size x Vertical Stretch is 1,000,000.
2) Keystone adjustment is not available in "S"
models. 3) Avoid using Keystone with Blanking.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 19, 2014 | Office Equipment & Supplies
I have a panisonic pt-lb50ntu Projector. It will only focus the center of the image. When you adjust the focus to the bottom of the image the top and center are out of fucus. The same goes for focusing on...
Is the picture a perfect rectangle shape on the screen. If not then either adjust the angle of the screen, or use the keystone function on the menu to correct it.
Does it still not focus correctly after doing this
Nov 12, 2010 | Panasonic PT-LB50U Multimedia Projector
I have a Panasonic pt-ae900u projector that doesn't project an image. The lamp fires up but no light makes it past the LCD panels, no video or menu graphics, nothing...help would be appreciated
I have the exact same issue with my projector and was wondering if anybody has an idea what the problem/solution could be? Have checked all internal connections, wiring, etc. but nothing is physically wrong with it. Powers on and off with no issues; bulb is working but no light out of the lens. Please help!
Oct 14, 2010 | Panasonic PT-AE900U Multimedia Projector
Dell 4100MP Image Not Centered Thru Lens
No to your question. The lens is fixed it cannot shift horizontally only although there are projectors that can do this. I am sure you have the front foot retracted? I have had to do the same as you are doing or find a lower table.
Jun 02, 2010 | Dell 4100MP Multimedia Projector
Pls help how to correct the blury display on the screen..i have tried adjusting the Zoom to normal position and the display is still blury not very clear
first the obvious: is the lens clean?
the designed throw distance on that model is 5' - 29'. if your projector is outside that, it won't be able to focus. if it is within that distance, reset the settings in the menu to factory default. if that doesn't help, you may have physical damage to the lens assembly.
Dec 02, 2009 | Epson EMP-S3 Multimedia Projector
How do I make my projector image square??
is the projector in the center , how is the angle
Mar 04, 2009 | Sharp NAVITAR 1.2 INCH BUHL LCD LENS,...
PICTURE IS ARCED AND OUT OF FOCUS
In the TV 's controls (menu) find the augmentation options. Most of the time an arced image is a miscalibration of these options. Focus can be fixed one of two ways, physically by adjusting the lens on the projector in the back of the television, and in the augmentation options.
Unfortunately I can't say more because I do not know the specific brand you have.
Sep 01, 2008 | Televison & Video
Blur
Well, that's a general statement. If you are looking to have the image look like a HDTV then you have the wrong impression of the projector's capabilities. At 800x600 resolution you will get a "good" but not great image especially if compared to a tube tv or plasma/lcd. If the graphics are sharp when you press the menu key then you probably do not have an issue. If, however, even the graphics are blurry, then you have to manually adjust the Grey outer focus ring on the lens. The inner ring will adjust the zoom. Hope this helps.
Feb 15, 2008 | InFocus X1A DLP Slide Projector
Projected image is not the same as computer monitor
as long as nobody has physically changed the lens poition, you can go into the menu on the projector and do a factory reset. this should default the settings back to where the installer put them.
Feb 05, 2008 | Mitsubishi ES100U Multimedia Projector
Service mode
there is no convergence. try resetting the settings to factory default through the menu. if you have a dlp, the colorwheel and dmd chip are set. if you have an lcd, the lcd panels are locked down. if they are off, you'll need to go inside and realign them physically. but that's chore, because you have to plug it in, turn it on, see which way you need to go, power down, unplug, remove the top cas, remove the main board, adjust, tighten, replace the board, replace the top, plug in, power up, check the image, and do this as manny times as necessary. leave it to the service centers.
Mar 11, 2007 | Boxlight -670k Multimedia Projector
Dell 4100MP Multimedia Projector Logo
70 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
