Question about 3M Projection Panel 6400 Multimedia Projector
3M Projection Panel
I am trying to locate a VGA to 26-pin M/M video cable, part No. DY-0205-1002-9 for a 3M panel type 6150. Do you have any idea where I may find one? Many thanks, Howard James
    Brigadier General:
  • 6,966 Answers
Based on your post/description, I will assume that you would want to connect a PC to a Projector.
For a 3M DY-0205-1002-9, pls contact:
3M Customer Information Center
Hale Avenue Business Center
3M bldg. 506, POCS Destination Code 0444
835 Hale Ave. North
Oakdale, MN 55128 Fax: 651-736-6320
or try
3M Visual Systems
1-800-328-1371
(Fax) 512-984-5105
Internet: www.3m.com/presentation
Email: OHP - presentations@mmm.com
EPS - techsupport@mmm.com
Should you opt for a replacement, you may want to consider DVI to VGA Analog Video Cable or similar products.
Alternately, you can use a converter box that will accept VGA inputs but whose output is DVI-D compatible. A fine example is VGA to DVI Converter/Scaler but of course any comparable brand/model should also work.
Hope that these be of help/idea. Pls post back how things work out or should you need further information.
Good luck and kind regards.
Posted on Dec 24, 2007
  • Louie  Role
    Louie Role Dec 24, 2007
    Hi again,
    In UK, you can try:
    Telephone: 08705 360036
    Postal address:
    3M United Kingdom PLC 3M Centre Cain Road Bracknell RG12 8HT
    Cheers.
  • Louie  Role
    Louie Role Dec 29, 2007
    Hi again,
    Any development(s) with your video cable search?
    Happy Holidays!
Security code program for ademco alarm 6150
6150 is the type of keypad you have the alarm system itself. The 6150 works on a number of different Honeywell panels. You need to locate the main metal box and open it. There should be a white sticker on the board with the panel type. (Ex. v10,v20, Vista...)
Oct 21, 2011 | Honeywell 5804 Ademco Wireless Security...
Tip
How to troubleshoot a system that boots up but wont display
  • VGA cable replacement
  • Needle-nose pliers
  1. Power downthe computer. Check the VGA cable running from the computer to the monitor. If the cable is not snugly seated in both ports, the video signal will not reach the monitor.
  2. Check the connector on each end of the VGA cable. Examine the nine pins on each connector. If any of the pins are bent or broken, the video signal will not reach the monitor. If there are just a few bent pins, you maybe able to straighten them with a pair of needle-nose pliers. Be careful not to break off any of the pins. If any of the pins are broke nor missing, you will need to replace the VGA cable with a new one.
  3. Disconnect all cables and peripherals from the computer. Open the computer case by removing the Phillips screws along the side or back of the case. Remove the cover or side panel to expose the internal components. Locate the VGA card and make sure it is fully inserted into the PCI card slot. If the card is not installed correctly, the video signal will not reach the monitor.
  4. Close the case, reconnect the power cord and all cables, and power up the computer. The video signal should display on your monitor.
on Jan 17, 2011 | Computers & Internet
How do i connect to an hdtv ?
You're going to need to connect a cable supported by BOTH the PC and HDTV. Check your HDTV's jack panel or manual. List the types of Input jacks it offers. The HDTV will likely have Component, Composite, DVI, HDMI and maybe even VGA jacks. Do the same for your PC. It likely has one or two Video Output jacks. Typical Video Outputs are DVI and VGA. The VGA type has been standard for years. It consists of a total 15 pins in 3 rows. The DVI has a number of pins, but most noticeable is a wide tab at one end of the jack.
If your HDTV has a jack that matches one of those found on the PC, you're in luck. Purchase a cable that will connect them - this would be either a VGA cable or and DVI cable. Nearly any inexpensive VGA or DVI (Digital Video Interface) cable 6 ft or less will do, but the better cables cost a bit more and when the distance is increased, the quality (or lack thereof) really becomes visible - especially on the lager HDTV screens.
If you want the sound to go to the TV speakers or elsewhere, you'll need to get a cable with a 3.5mm stereo plug (or whichever type your PC has - but that's the most common) to RCA or whatever the audio input jack type is that is associated with the video input you chose. The audio input must be the one associated with the video input - other wise you will not hear the audio on input 4 while watching input 3. The PC audio out is analog, so do try to put the signal into a digital input.
If you don't have a matching video input jack, you'll have to purchase an adapter or new video card with jacks that match your TV. Do not buy simple adapters that change VGA to DVI as they will not convert the actual analog VGA signals to Digital Video signals expected by the HDTV's DVI jack. The best bet is to buy a modern video card supported by your computer's mother board and OS that has a fair amount of memory (512 MB is a good start). If your HDTV has HDMI jacks and you wish to play the sound from the HDTV's speakers, get a card with HDMI output and buy an HDMI cable. It will send both the sound and video to the HDTV for you.
You can read a nearly endless list of articles about HTPCs aka "Home Theater Personal Computers" for ideas and deep discussions about everything from soup to nuts to implement, design and set up on google.
I hope this helps - good luck!
Nov 12, 2010 | Gateway GT5228 PC Desktop
I have a customer on the phone who has a olevia flat screen and can not locate an input for his cable wire. where are they located?
here are the only signal inputs located at the back of the tv.
1 x HDMI input ( 19 pin HDMI Type A )
2 x component video input ( RCA phono x 3 )
1 x VGA input ( 15 pin HD D-Sub (HD-15) )
Audio line-in ( RCA phono x 2 )
2 x S-Video input ( 4 pin mini-DIN )
2 x composite video/audio input ( RCA phono x 3 )
1 x headphones ( mini-phone stereo 3.5 mm )
1 x SPDIF output ( TOS Link )
1 x audio line-out ( RCA phono x 2 )
1 x subwoofer output ( RCA phono )
1 x serial
If you are looking for a coaxial cable input.. it is actually not available so you have to connect a converter from coax cable to RCA cable for you to connect it on your tv.
Jun 04, 2010 | Olevia 237T 37 in. LCD TV
I have just got a Toshiba 37AV502R flat screen tv. I want to connect the digital audio output (optical) to my older 5.1 speaker system. The input on the sub woofer is a 15 pin VGA... I can't seem to find a...
Is this sub a Bose. The only reason you would see a VGA type connector on a sub is if it is dedicated to somthing else such as Bose 3-2-1 system. This is not a standard VGA input and can only be connected the the dedicated head unit. I need more info on the sub. Brand and model. Ther should be an analog audio input on the sub. This will be sufficient.
Oct 31, 2009 | Toshiba 37AV502R 37 in. LCD TV
Insignia LCD tv 32".....
It's either the VGA cable you are using has a bad pin or the RGB/Color Scheme is set wrong. So try another VGA cable or try the LCDTV on another PC.
Feb 22, 2008 | Insignia LCDTV26 26 in. Television
Tv/pc
Your Panasonic TC-26LX20 26 will only allow video inputs through the:
1. composite video/audio input ( RCA phono x 3 ) - front or rear
2. S-Video input ( 4 pin mini-DIN ) - front or rear
3. component video input ( RCA phono x 3 ) - rear
4. HDMI ( 19 pin HDMI Type A ) - rear
Depending on the output(s) available from your PC, you can use any of the following:
a. the yellow RCA female
b. S-Video output ( 4 pin mini-DIN )
c. VGA (which normally goes to the monitor) but would require a VGA/HD to HDMI Format Converter such as the one here
Should this be not enough information, please post back with what PC brand/model that you have. Additionally please specify what Video Card are you using if your PC is a desktop.
Nov 17, 2007 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Connecting a FLat Panel TV to me PC
Check your owners manual.
You need either a 15 pin VGA cable or a DVI (Digital Video In) cable.
Look at the back. If you have a small D-Type connector with 3 rows of 5 holes you need the VGA cable.
Of you have a rectangular connector with rows of angular holes and two slotted holes on one side then you need a DVI connector.
If you're current monitor cable is removable from your monitor you can likely use it.
Nov 04, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
3M Projection Panel. Model Number 4180
input ac 120V 60HZ 40 W
output DC 12V 1.5A
as to any other functions I have no idea
May 06, 2007 | 3M Projection Panel 6400 Multimedia...
3M Projection Panel 6400 Multimedia Projector Logo
461 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
