Question about Health & Beauty
I can't get my vision fitness deluxe (almost 2 years old)
Treadmill belt to tighten , everytime I try to run on it, the belt slips, stops and may or may not restart
  • 563 Answers
Make sure the rollers are in alignment and in equal spaces apart. Also no grease or dirt present on the rollers and belts. Belt must be OEM. (original equipment manufactured). If the belt is aged, you may have to get a new one.
Posted on Oct 19, 2009
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
9500 hr belt stops when stands on it and funny noise from machine , noise stops when adjust front tension bolt but belt still loose
see the video and proceed. This happen because the lack of maintenance schedule . If the problem remain after you did LUBE is time to replace the old board belt. God bless you
Apr 01, 2013 | Life Fitness Used 9500 HR Treadmill
My t9600hrt treadmill stopps working after about 15min and then i can start it up again and same
Lube the treadmill for deck belt+roller bearing too.
This happen because the lack of maintenance schedule.
See the video, if after you fix it, the problem remain, is TIME to replace the old deck board.
God bless you
Feb 25, 2013 | Vision Fitness T9600 Deluxe Treadmill
Belt is slipping
see the video attached. and fix it. God bless you
Nov 25, 2012 | Dmm Vision Fitness T9500 Treadmill
I have a pro-form 680 LT less than a year old. The belt seems loose, it catches as I run and I about fall over.
The walk belt should be tight (about 1.5" to 2 " when lifted at the edge), if not tighten screws at the rear. If the belt is tight enough then pull the front cover off and check the front roller. Sometimes the plastic drive pully slips on the front roller. If it only stops while you are running and is fine when you walk, i would go to the front roller.
Nov 02, 2010 | Proform 680 LT Treadmill
Reebok 8050es treadmill walking belt has started slipping/skipping. It has been oiled and it is 2 years old.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
May 05, 2010 | Reebok 8050 ES Treadmill
The belt is slipping
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Apr 29, 2010 | Dmm Vision Fitness T9500 Treadmill
Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
Treadmill seems to slip while running,
Feb 22, 2009 | Proform XP Weight Loss 620 Treadmill
Belt is slipping
Jan 26, 2009 | Proform 370E Treadmill Walking Belt
Health & Beauty Logo
98 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
