Question about Canon PIXMA MP190 All-In-One InkJet Printer
I loaded the paper into the tray,but the alarm error light with code E2 is lit. and so i think its not detecting paper, which wont let me insert the ink cartridge ..what am i doing wrong???
How do i load in ink cartridge?
Posted on Mar 06, 2010
  • 117 Answers
Set paper in ASF, and
press the OK button.&yor printer open cling
Posted on Oct 07, 2009
Cannon mp530 says load paper when paper is loaded
Paper not loaded error is displayed by the printer when the printer doesn't detect any paper. Here try this one.
  • Make sure that your paper is properly inserted.
  • If properly inserted and still the printer doesn't detect it. Try putting more amount of paper in the tray.
  • Be sure that there are no damaged paper in the tray.
  • Clean the rollers using a cotton buds and a clean water.
  • Now try printing again.
Hope my solution will help. Thanks for using fixya.
Jul 08, 2011 | Canon Office Equipment & Supplies
Paper is inserted properly but error message keeps saying "Load paper face down in Main tray"
i think the printer has 2 trays, one down and the other one on top from where you insert the paper. load the paper there as well. if there is only one tray then check the paper sensor in the bottom, if the paper end sensor comes out of position then it will not detect the paper.
Jan 06, 2011 | HP Photosmart C6280 Printer
My cartridges on my canon pixma mp190 do not move to the center when i open it. it is also blinking an error of E2 and the alarm button is blinking
Is it brand new? The print head rail may have a protective plastic piece covering it. Pull that out and it should work better.
The code "E2" on your Pixma MP190 indicates that the paper is loaded incorrectly.
After correcting the problem that caused the error, press the or button.
  1. Remove paper from the rear tray.
  2. Open the paper output tray and extension. (See and in Figure 1 below.)
  3. Set the paper thickness lever according to the media being used. (See in Figure 1 below.)
    Note: For paper thickness lever settings, use the following setings for the media type being used: Right side: Envelopes / T-Shirt transfers. Left side: All other media types.
    * Figure 1
  4. Divide the stack of paper into two or three piles.
  5. Fan out the sheets of paper so that they do not stick together.
  6. Load paper in the rear tray with the paper's print side facing up. (See in Figure 2 below.)
  7. Align paper to the right edge of the rear tray. (See in Figure 2 below.)
  8. Pinch and slide the paper guide to the paper's left side. (See in Figure 2 below.)
    * Figure 2
  9. Press or button to clear the error.
Dec 02, 2010 | Canon PIXMA MX310 All-In-One Printer
Whenever I try to print a page, error E2 appears, even reinstalling does'nt solve the problemm
E2, Error Code [1000] or Alarm LED blinking in 2 times is mean No Paper in Auto Sheet Feeder. Insert paper in ASF and press OK button.
May 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have an error E2. I have tried to reset the
E2 just says to insert paper and press OK, for some reason the paper is not feeding or the sensor inside is not seeing the paper. Check inside where the paper goes for any obstruction, sometimes ink pens, paper clips, jewelry, etc... fall inside the back and stop the paper from feeding. If your printer has 2 choices for paper make sure the paper is in the right tray and select the correct tray.
Feb 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error code 5100 on off blinks twice alarm blinks once E2 in window
Errror code E2 indicates a paper-out situation. Fill the paper. If it's full, fill the paper out and reinsert it. If that doesn't work, try this...
1. Power off the printer
2. Unplug the printer's power cord, wait 5 seconds then replug the power cord in.
3. Hold the Power button for 6 Beeps
4. Release the Power Button
This will reset the printer and should resolve incorrect detection problems
Nov 15, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Hi, While loading paper I'm getting an alarm saying E2 though papers are present in the paper tray. I 've pulled the clip in the paper feeder to the left, kept the paper i.e. alligned it to the right of...
Does your printer have a paper tray on the bottom as well? If so there's a feed switch that tells your machine to use the tray or the rear feeder. There's also a small printer picture with a light that either is lit for the top or bottom feeder. To be safe, put paper in both trays.
Aug 13, 2009 | Office Equipment & Supplies
My canon M 160 jammed, I pulled paper thru, now it won't print
E2 is "NO PAPER" error but in most case it's showing when the paper feed is in incorrect position.Check it movement correctly and check for any objects drop in printer.
Jun 14, 2009 | Canon PIXMA MP160 All-In-One Printer
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Canon pixma mp145
hi, i have problem.
my canon pixma mp145 can't operate. the alarm sign is ON and the light for black ink is blinking, and the sign e4 come out . any body can help me what to do?
thanks
rose, malaysia
Aug 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP190 All-In-One InkJet Printer Logo
587 people viewed this question
old marine
old marine
