Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag washer stopped working at the rinse cycle
Maytag washer Ensignia Series - the cycle was running fine until it hit the rinse cycle, and then keeps shutting itself off and making a slight humming sound. Only a small amount of water filled up and now it won't do anything...(stopped working completely). I checked the fuse box - it is not that (the power source). Not sure whether to open the back of the washer and dig in....wouldn't know what I'm looking for anyways....Lee Ann in South Florida
  • 464 Answers
Do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Posted on Oct 11, 2009
Washer will work in Rinse or Spin settings, but not any wash settings
If you are doing the normal procedures and the water elimination function is working, you have power to the circuit board and controls. The circuit board wash cycle section is independent and aligned with the timer circuit, thus the Wash Cycle Controller has failed. All of the functions or options are one the one board and a replacement board needs to be purchased and installed.
Feb 26, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag ensignia makes a great deal of noise during rinse cycle
"If you dont have a noisy spin cycle and the noise you hear is only on the rince cycle, dont be worried, as this is totally normal. Water sprays onto the drum while the spin cycle is in progress and rewets the clothes to allow any existing soap to be desolved. This noise is in effect the water hitting the drum during the rince part of the cycle.
Sep 03, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
My maytag ensignia washer vibrates/shakes as it rinses
you need to level the unit and then lock the jamb-nuts between the leveling legs and the bottom of the units base structure,use a level and check the top,then level the unit as best as possible,per the floor grade,then tighten the jamb nuts to keep them there
Jul 05, 2010 | Maytag Ensignia MAV4758AWW Top Load Washer
My Maytag Ensignia washer is making a clunking noise like something is loose when it is in the rinse cycle.. also does not appear to be spinning as well as it should. What could be wrong with it
Mine had the same problem! Turned out to be the transmision going bad. My machine is only three years old. Transmision cost over $250 Not worth fixing. The inside of this machine is very poor quality. I am very disapointed. Maytag not the quality it once was. I WILL NEVER WASTE MY MONEY ON A MAYTAG PRODUCT AGAIN
May 24, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
The water continues to run into my Maytag Ensignia after the cycle is complete
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Oct 05, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag ensignia washer...cold water settings
You need to remove the cover and check the voltage to the cold water inlet valve. Do this with a volt meter while it is set to fill with cold water. It is most likely an AC voltage that is around 24 volts. If you have voltage then the valve is most likely bad.
Feb 16, 2018 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
597 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
