Acer Internal 50x CD-ROM Drive
Problem for Acer (99.B0311.002) Internal 50x CD-ROM Drive
Similar Problem
By marshall8806 on Oct 07, 2009
CDROM Drive won't show up in the BIOS as an attached device either.
Solution #1
posted on Oct 07, 2009
Not Rated)
pcmatch
Rank: Guru
Rating: 92%, 21 votes
If it is a SATA drive, check the manual of the motherboard for SATA options/configuration in BIOS.
If it is an IDE drive, I suspect a bad configuration.
Set the jumper in CS (cable select) mode. You may connect it to the primary (end) or to the secondary (middle) connector of the IDE cable. Be sure there is no other drive on the same cable. Turn on your computer and verify if there is any changes in BIOS.
If the drive is not seen in BIOS the cable or the unit may be damaged or incompatible with your computer.
If the drive is seen in BIOS turn the computer off.
Now, you may add any other drive (if any) on the remaining connector on the same cable as it follows :
- set the jumper as Master or Cable Select if you connect the drive to the primary connector (end), or
- set the jumper as Slave or Cable Select if you connect the drive to the secondary connector (middle).
Was this helpful?
Yes
No
Popular Solutions for Acer Internal 50x CD-ROM Drive
Questions and Unsolved Problems for Acer Internal 50x CD-ROM Drive
Do you recommend Acer (99.B0311.002) Internal 50x CD-ROM Drive?
Answer
Answer
cd drive can't read the cd because it doesn't recognize the formatting
Answer
download driver axioom54n
Answer
My Lightscribe DVD Supermulti Drive /CD Writer is not opening its slot. When OPEN button is pressed,... (More)
Answer
My Mashita ujda 700 will recognise my dvd-r or dvd-rw
Answer
I have an acer aspire 5520 and the computer tells me the cd rom drive is working properly, but I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Internal 50x CD-ROM Drive:
Top CD ROM Drive Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more CD ROM Drive Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
