Question about GPS
My gas heater won't come on. It's not the therocouple because the pilot is lite. The thermostat on the wall works for my AC. What do I do?
  • 74 Answers
It's possible the gas is just turned off at the heater. Most gas heaters have a valve which turns off the burner while allowing the pilot light to remain lit.
Your heater should have a little decal that tells you how to start it up. It usually involves pressing a big red button while you turn the valve (to prevent accidental turn-on). If your heater has such a label, follow the instructions on it carefully, and the heater should come on.
If that doesn't work - then this is not a good problem to get solved on the Internet. Think about it: if you do something that causes a gas leak, you could be severely injured or killed just by breathing too much of the gas, or lose your home to explosion or fire.
Look for the restart label, but if you don't find it or you follow it and it doesn't work, PLEASE contact a trained plumber who handles gas. Good luck, be safe!
Posted on Oct 07, 2009
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
Williams wall heater, lite pilot and heater comes on okay, but will only come off when I disconnect the thermostat?
If you have to disconnect the thermostat wire at the gas valve then it is either a shorted thermostat or a short in the thermostat wire.
If you only have to disconnect the thermostat from the wire, then it sounds like a bad thermostat, replace the thermostat
Apr 11, 2013 | Williams 2509612 Ceramic Mid-Size Heater
How do you wire the thermosat on williams wall furnace model 3509622
This heater has 2 type gas valves one valve has the thermostat built into it. No wiring needed for that puppy. Looks like this:
So I am guessing that one ain't you.
Your heater must use a millivolt gas valve with the 2 wire wall thermostat. The pilot generator does 2 things. It holds the pilot on and it produces voltages that operate the solenoid and open and close the valve when the room thermostat makes contacts. So what goes wrong with these? The pilot generator will sometimes hold the pilot flame but whn the 2 wires are touched together or you tun on the wall thermostat the whole thang just dies. That my friend is a weak thermopile generator. The other thang that goes wrong is the solenoid on the gas valve is open and therefore the gas won't come on. Their is also a fuse mounted on there that melts and kills the magnet that the generator holds in for the pilot.
Nov 04, 2011 | Williams 2509612 Ceramic Mid-Size Heater
I have a Williams Ceramic Gas Wall Mounted Panel Heater, the pilot is on but the furnance is not working
Jump the two wires going to the thermostat, if it starts , you have either a bad thermostat or a broken thermostat wire. If it does not fire up, you will need to check for 24 volts AC going to the gas valve from the transformer. If you have voltage, you have a gas valve issue. If no voltage, check for a limit switch that may have overheated with an Ohm meter. If they all test good, replace the transformer.
Jan 22, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Unit randomly shuts down
you could re locate your therocouple away from flame
Dec 22, 2009 | Desa International CBN30T Central Heating...
The pilot light on my kozy world ventless wall heater goes out after it burns for a while. Even quicker when the blower kicks on.
weak pilot flame: should wrap around therocouple.
blue flame with yellow tip not yellow and lazy.
if flame good replace thermocouple
Oct 26, 2009 | The Companion Group Kozy World Portable...
Problem with pilot shuting after heater thermostat cycles off
It could be a few things:
1.Not enough fresh air or the unit is too large for the room it is installed.
(Try to open a window)
2. It could be low gas pressure. This can happen it your LP tank is low or something is wrong with the line.
(Call your gas or LP company)
3. ODS Pilot may be clogged.
(Use a vaccum cleaner, pressurized air, or a small, soft bristled brush to clean).
If this does not fix the problem you may need to replace the pilot. You can contact them at 800-446-1446 or on-line at www.masterparts.net. I hope this helps!
Jan 01, 2009 | Desa International GWRP26T Infra-Red Wall...
Laars lite 2 pool heater burner not lite
If the pilot flame is not strong enough, it will not tell the gas valve to open, or if the gas valve is not getting the signal to open, it won't. Check all wire connections at the thermostat and gas valve. Check ground wires. Clean the pilot light and flame rod.
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
GPS Logo
51 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
