Question about Grinders
Grinder wheel wobbling
I have an 8'' bench grinder. One of the wheels is wobbling. I checked both wheels for flatness and they are OK. The spindle appears to be running true with no indication of a variance. Any suggestions?
    New Friend:
    Problem Solver:
  • 6 Answers
The grinder is made by Delta, and the design is known to be flawed.
Look at those stamped-out wheel flanges, and see what they mount against - a small shoulder on the shaft. The best I have been able to do is rotate it until I find a 'sweet spot".
Posted on Apr 07, 2010
    Top Expert:
  • 12,173 Answers
Check bearing for play and or race for wear on wheel
Posted on Oct 06, 2009
How do I dress a grinding wheel on a bench grinder with a viberating wheel.
Hello.
First of all I must warn you of the dangers bench grinders can represent. Here in Britain no one connected with a business is allowed to carry out any maintenance on any none-portable grinding machine unless they have attended and passed a course on the subject and every employer must keep a register recording what maintenance has been carried out and by whom. Grinding machines have been responsible for many industrial "accidents".
Householders and private individuals are exempt from the Law but cannot afford to be less well informed even though the five and six inch bench grinders sold to the domestic user represent a somewhat reduced risk, great care and precautions are still required, not the least of which is the use of good eye protection even if the grinder is fitted with shields.
The first problem about dressing the grinding wheel of a grinder intended for the domestic market is the tool rests are usually too small and insubstantial for the vibrating star-wheel type wheel dressing tool to be used correctly.
A demonstration would be the best way to learn how to dress a grinding wheel and there are many available on Youtube and here is a link to a particularly good video.
https://www.youtube.com/watch?v=RqxfJ4DtZtQ
Finally, it is best to be aware of one little thought about problem. There is an optimum speed range when a grinding wheel works efficiently and small domestic grinders barely turn fast enough for them to be properly efficient, probably because it is reckoned price and user safety takes priority over efficiency.
The speed that is of concern is the surface or peripheral speed of the grinding surface rather than the rpm of the spindle and should that speed fall too low the wheel will not be able to operate efficiently, will become dull more quickly with a greater tendency to clog and the wheel will become hot in use and hot grinding wheels soon become dangerous.
I hope you will be able to see that by reducing the diameter of a grinding wheel by dressing it also reduces the surface speed of the grinding surface even though the spindle speed remains the same. The relationship between surface speed and spindle speed is why small grinding points need to spin at 20,000 rpm and an eight foot wheel at just a few hundred rpm - in both cases the surface speed is similar.
A domestic grinder should not be used for heavy work but as the size of the wheel is reduced it should be used only for increasingly light work and if it is desired to carry out "normal" grinding operations it would be better to replace the wheel sooner rather than later.
Feb 19, 2015 | Craftsman Grinders
Adjustsettings on Oregon 511AX bench grinder
there is a nut and bolt that holds the little shelf below the grinding wheel. Loosen it and adjust the shelf or rest to within approximate ly1/8 inch of wheel for safety.
Nov 27, 2014 | Oregon 511ax 115-volt Bench-mount Chain...
Both wheels have a noticeable wobble. Can this be corrected?
Yes, the wobble can be fixed. First, remove both wheels and check the shaft bearings/bushings for wear. Make certain the grinder is unplugged and mounted securely. Try moving the shafts up, down side to side; there should be little or no noticeable movement. If there is movement it is a major(time and money) problem. I'm not familiar with what the shafts ride on. It could be, ball bearings(the best-long lasting, least friction, most accurate, but expensive), sealed bearings(almost as good as ball bearings, with many of the same attributes) and bushings(least expensive to produce and fit and cause the most friction. If excessive up,down side to side movement is present a decision must be made as to how much money/time you want to invest. If the shaft exhibit little movement; check if the shaft is running true/straight. Turn the grinder by hand while observing the shaft for bends. If none are seen by eye use a magnetic base micrometer to check run out(deviation from straight). If a micrometer isn't available; bend a short length of wire(coat hanger works nicely) with a small hook on one end and then put a pointer end on the other. Put a screw thought the end with the hook to mount it to the base of the grinder. Then bend the pointed end so it just touches the shaft. Rotate the shaft and notice if the distance changes between the point of the wire and the grinder shaft. Repeat for the other side. A couple of thousands won't hurt. However, any more and the cost effectiveness of tearing the grinder apart straightening the shaft must be considered. The most common cause of grinding wheel wobble is the wheels becoming out of true and/or unbalanced. This is easily cured with a wheel dressiing tool. The tool grinds the wheels in place. By gringing the wheels on the grinder they balance the wheel, true the wheel to the shaft and clean it of imbeded soft materials, aluminum, wood and so forth.
Feb 23, 2011 | Dewalt DW758 Heavy Duty 8" bench grinder
Have 25 year old Wilton belt grinder. Belts seem to wobble when running then will just not track. Not sure what part needs replacement.
The motor and grinder pulleys need to be perfectly parallel or the belt will track to one side or the other. The belt must be uniform with no stretch or wear points which will cause erratic travel. Hope this helps!
Nov 09, 2010 | Wilton Variable Speed Wheel Grinder, Bench...
How do I remove the wire brush form a model 9410 grinder?
An ajustable wrench for the 'wire brush end' nut,and a visegrip type plier for the opposing wheel end. Wrap the jaws of the visegrip pliers with tape to protect the spindle opposite the wir wheel. Loosen the nut on the wire wheel end,counterclockwise.REMEMBER: lefty loosey-righty tighty.
Jul 22, 2010 | Craftsman 6" Bench Grinder with Lamp
BROKE THE TOOTHED BELT ON MY BENCH COMBO GRINDER/WIRE WHEEL
I had the same problem, I went to a pawn shop, some times they have part for some of the items they buy . I wish you luck in finding one. it took me some time. hope you find one
Apr 20, 2010 | Orion Craftsman Professional 8 in. Bench...
How do I lock up the axel on my bench grinder to retighten after replacing the wheels? Also what is the torque setting?
Just put a wrench on the nut on the opposite side to hold the spindle. They will both tighten at the same time. Tighten them "snug". The threads are made so the nuts will self tighten or should I say will not come loose due to the way the wheels turn and pressure from use is applied.
Dec 02, 2009 | Delta 23 - 725 8" Industrial Grinder
Bench grinder, 110/220?? wired up properly according to diagram on grinder, just turns on as soon as it's plugged in but it just humms, it does not spin the grinding wheel.it is a monster w/ a 3/4 hp...
LIKELY the capacitor which is usually in the base is bad.
The capacitor shifts the phase angle in one of the two windings which creates a pseudo rotating field to start rotation.
Nov 07, 2009 | Saws
Older black & decker bench grinder
Usually a new wire wheel comes with different size bushing just for the problem you are describing. Either that or take it back and get one specifically for your tool.
Jan 31, 2009 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Bench Grinders Usage
Grinding is the fastest way to deburr a sharp corner or dress the end of threaded rod or bar stock that's been cut to length. Fit a grinder with a wire wheel, and you have a handy tool for removing rust. Then switch to a buffing wheel and you're ready to polish metal to a mirrorlike sheen. But for most of us, grinders are essential for shaping and sharpening hardened tool steel and high-speed steel.
Aug 27, 2008 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Grinders Logo
171 people viewed this question
Top Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Vernon Taylor
Are you a Grinder Expert? Answer questions, earn points and help others
