Question about HP Pavilion F1703 17" LCD Monitor
How do i turn my monitor right side up - HP Pavilion F1703 17" LCD Monitor
    Guru:
  • 81 Answers
how do i turn my monitor right side up - nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=324214I guess this is your monitor, If you want to turn it right side up physically. It's not possible, as it has a fixed base. We can change the picture right side up, but that can be done through your graphics card utility software.
Regards,
Shrey
Posted on Oct 06, 2009
The light goes off the monitor and it dont turn on when i turn the computer on.
Are you saying when you end up holding the button on the side of the monitor so that the screen turns on solves the problem? more info could help!
Jan 31, 2014 | Gateway LP2207 LCD Monitor
Monitor problems
Have you tried to reset all your setting to default through your monitor? Sounds like an overscan issue, like the monitor is trying to display video past the actual size of the monitor so it raps around itself. You could try and lower the screen resolution on your desktop and see if it goes away as well...
Nov 04, 2013 | Computers & Internet
How to change orientation of monitor
I'm a little unclear of what you are asking.
1) Screen has turned on monitor?
Press the CTRL key, and ALT key down at the same time.
Now tap on the Left Side Arrow key, until the screen is oriented correctly again.
2) Screen on monitor has shifted left, right, top, or bottom?
Use the controls on the monitor to set it correctly again.
3) Using dual monitors?
Right-click on an empty space on your desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on Settings.
The monitor 1 icon is supposed to be your Primary monitor.
The monitor 2 icon is the Secondary monitor.
Ordinarily the Primary monitor is on the LEFT side, and the Secondary monitor is on the RIGHT side.
Just as shown in the Settings window.
If you wish to move a monitor to the other side, go to the monitor icon you wish to move.
Put your mouse cursor on the monitor icon you wish to move.
Left-click, and hold the left mouse button down.
Now drag the monitor icon you wish to move, to the other side.
Not doing it for you?
Then post in a Comment with more exacting information, as what it is that you wish to do.
Regards,
joecoolvette
Aug 02, 2012 | E-Machines eMachines Desktop PC
I cannot see a button or anything to turn on my monitor.
It looks like you didn't notice the buttons, there should be three buttons on the right pane of the monitor (vertical and when you look at the monitor, they are on the right-hand side), or at the right side panel, which isn't visible from the front, you have to look at them from the right side. Refer the screenshots below (buttons are highlighted):
Front
Right Panel
Hope this helps, let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 22, 2011 | LG Flatron L1718S LCD Monitor
Lcd turns red
is there a speaker or magnet adjacent to the monitor?
Dec 25, 2009 | Sony CPD G420 19" CRT Monitor
Acer monitor x193HQ when turned-on has black
you need to center the image using the control settings on the monitor panel, hope this helps
Jun 10, 2009 | Acer AL1916W 19" LCD Monitor
My ViewsonicVP930b Monitor Suddenly Turns Off
This is a classic VP930 problem.
It is caused by bad capacitors in the power supply circuit.
Open the monitor, and look at the power board. There are six capacitors. Replace the 220uF @ 25V and the 1000uF @ 16V capacitors. I would recommend replacing them with 35V and 25V capacitors respectively.
If the serial number on your monitor starts with Q8H you could also have a bad IC on the main board. Q8 on the main board is an FET in an IC package. If this problem persists solder a wire from the right side to the left side. There is one pin that turns the IC on and off. All the other pins (per side) are soldered together. Do not solder the pin on the left side that is by itself. Just leave it. Solder ALL the other pins on the left to ALL the other pins on the right.
Remember, do this ONLY if the problem persists after replacing the capacitors AND if your serial number starts with Q8H.
Apr 20, 2009 | ViewSonic VP930b 19" LCD Monitor
Display on moitor
You will need to go into the display adapter from the control panel and select rotate display. Some monitors have are configurable for ceiling mounting for class rooms and other public viewing.
Nov 21, 2007 | Acer AL1916W 19" LCD Monitor
Display on moitor
just press the auto button on panel it will adjust the screen
Aug 17, 2007 | Compaq FP 7317 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
231 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
