Question about Whirlpool Duet GHW9150P Front Load Washer
The conrtol panel says control locked - Whirlpool Duet GHW9150P Front Load Washer
  • 5,911 Answers
The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set by leaning against the panel, or following power interruptions due to brown outs and black outs. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not correct your problem, then you have more serious problems than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Posted on Oct 07, 2009
Testimonial: "Thanks you save me alot of trouble and probably money. It was an easy fix but I didn't know the answer."
We have to replace the control panel on our Amana AOES3030E wall oven. We have the part but how do we access the area where the new part needs to go? I'm not seeing how in the user manuals I looked...
To replace the control panel, the wall oven needs to be pulled out about 10-12 inches to access the conrtol panel..it has screws on the side AND in the back of control panel taht have to come off to get into panel...typically it can be pulled out fairly easy a couple of feet without it tipping and falling out of cabinet but only pull out as little as necessary
Aug 25, 2011 | Amana AOES3030 Electric Single Oven
None of the conrtol buttons on the Electronic Triple-Cool System respond when you push them. It seems like it is frozen (no pun intended) or locked up. Therefore we are not able to adjust the...
Unplug the refrigerator for 10 minutes then plug back in.Reset controls to your liking. If that doesn't help, you may need a visit from a technician.
Sep 26, 2017 | Maytag MBF2262HE Bottom Freezer...
The conrtol locked light is lite washer wont do any thing.
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control and to eliminate the possibility of an electronic glitch if the End of Cycle button does not unlock it. Replace the control if unplugging and the End of Cycle button fail to unlock the control.
Oct 25, 2010 | Whirlpool GHW9200L Front Load Washer
I need urc 601 surfer 6 in 1 remote conrtol codes
Try: 0166 0127 0111 0003 0022 0036 0045 0176 0101 0102 0050 0051 0052 0126 0139 0163 0185 0245 0046
Oct 23, 2009 | Televison & Video
Amana abl2227fes freezer works but the refrigerator does not
If the board is not opening and closing the damper from the freezer to allow air flow, the board will need to be replaced. If the control does make any of the damper parts move then it would be a mechanical problem with the damper conrtol linkages.
Sep 10, 2009 | Amana Easy Reach Plus ABL2227FES Stainless...
I have power going to control panel of heater. I
raise t temp if problem continues change t board
Sep 01, 2009 | Pentair Minimax NT Heater
My wireless conrtoller will not work unless it is plugged into the PS3. Am I missing something?
It might need to recharge, unless the conrtoller has a faultly battery in it so you might need to speak to sony,
Aug 26, 2009 | Sony Wireless Controller for PS3
Hi ,i have a saab 93 linear sport 05 ,all controls on drivers door dont work.i have had the door skin off to refit the door speaker,since putting it back together nothing on the drivers door and the...
Hi sounds very much like you have inadvertantly unplugged or trapped a wiring harness, remove door panel again and check especially around / under door conrtols
Nov 02, 2008 | Saab 9 Cars & Trucks
Control locked light on
The button on my Epic version is called the "Cycle End Signal" button.  I pressed it for 3 seconds and the "control locked" light went off and the washer started.  This button is on the far right, just like premm said, near the "Off" button.
May 09, 2008 | Maytag EPIC MFW9700S Front Load Washer
Control Locked
push and hold in far right button on conrtol panel( look closly you see control lock) hold for 3 secs and it will turn off
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
