Question about Dahle Office Equipment & Supplies
Shredder doesn't work. Shredder has two lights on top, one green one amber. Both are on. Made sure door for waste basket was closed. Still nothing.
fellowesrep
  • 102 Answers
SOURCE: Aurora Electronics AS1018CD Shredder
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Posted on Mar 02, 2008
checkitright
  • 1362 Answers
SOURCE: Shredder won't grab paper
there has to be something in the path.
once you put the paper in it triggers a sensor that rotates the blades and grabs the paper there is nothing else in between the entrance and the blades. get a flash light and lok in to see what is blocking the path.
unless there are some paper in between the teeth /blades, that need to be cleaned out.
Posted on Sep 05, 2008
SOURCE: OM 99727 shredder not working
I had this same problem. This is what I did to fix it.
When I went to ShredCare.com (the recommended web site for technical support of this particular shredder), I read that 'Most models of shredders have a safety interlock switch that is activated by the basket.' Upon looking closely at my basket and the shredder, I found this safetly interlock switch and made sure to align it with the proper position within the basket. There is only ONE way to place the shredder on the basket and have this safety interlock switch activated. The switch is located on the underside of the shredder. Align this switch with the ridge on the inside of the basket. Listen carefully and you will hear the switch 'click' when in the right position. Mine is very touchy. I've even had to press in on the side of the basket while shredding to make sure that the ridge and the switch are making contact.
Hope this helps!
Posted on Dec 26, 2008
  • 1297 Answers
SOURCE: Shredder will not run. When manual forward is
Chek the input sensors.Clean it used the vacum cleaner.
Posted on Aug 13, 2009
FixinFax
  • 3085 Answers
SOURCE: My PS-65C,won't work because.............
Don,
Sorry, no spare parts are available.
Posted on Sep 18, 2009
Red light and green light on but motor will not come on
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 13, 2013 | Fellowes PS60-2 Shredder
Spl-s302d shredder door open
Check to see if there's a little piece that broke off from the door. This would be the "safety interlock switch" or little thingy that pushes down the basket sensor. The basket sensor is located on the bottom front of the shredder. I bent a paper clip to hold down the metal switch (basket sensor) and taped it to the front of the shredder with scotch tape.
Jan 07, 2012 | Staples Office Equipment & Supplies
We have an Intimus 502 that displays along with the power green light, the amber light for door open, basket full constantly. jumpered the magnetic door switch and nothing changed. checked basket full...
I have the same problem I am yet to find a solution.
There is a long flat 2cable marked red/white which is connect on the main board the connecting points are short but why that long cable.
Aug 04, 2011 | Intimus 502 Shredder
Put too much paper in shredder- it jammed. I reversed the paper flow. Unit turned off. I've cleared the paper jam, but unit won't power up.
Sounds like the waste basket is not pushed all the way in. Your basket will have a piece of plastic (not in the middle, this is just a guide) probably on the right hand edge of the basket. This little piece of plastic pushes in on the safety switch. Take a flash light and look closely and you will see how this works. Take a Q-Tip and push in on this switch and see if it will power up.
Nov 15, 2009 | Royal 85X Shredder
Don,
Sep 17, 2009 | Fellowes 3011001 Shredder
GREEN POWER LIGHT ON RED LIGHT BLINKING MACHINE WILL NOT GO IN FORWARD OR BACKWARD
Common reasons for this is dirty or blocked sensors on top and under the cutter asm.Also, the waste basket door sensor or switch is activated.
Jun 03, 2009 | Achiever CCS-1500 Cross-Cut Shredder
Fellowes PS60C-2 shredder doesn't shred
there are two switches under the cutter area. 1 for sensing when your basket is full, (sometimes these bin-full flaps get stuck in the up position, energizing the switch) and the other is a switch that detects if your basket is installed. fellowes has modified these shredders so many times, that there are alot of different configurations. look for something that resembles a flap under the head and make sure its in the down position. as for the basket sensor, some baskets had 2 projections on the left and right top of basket. one may be broke. if so, you can "cheat" the switch with a screwdriver to see if thats the problem.
hth,
razors
Apr 14, 2009 | Fellowes PS60C-2 Shredder
Shredder won't turn on
On the right side of the waste basket(as you face it) is a tab that pushes a button on the shredder when it is in place. The tab is not making contact with the button. Push the side of the basket where the tab is when you have paper to shred in it. If it begins to shred, you may have to bend the basket inward so that the tab makes contact. I have had this problem.
Aug 24, 2008 | Office Depot Ativa DQ60M Shredder
PS-70 Shredder problem
Make sure that the shredder is locked down in its case by pushing down on all 4 corners.
Since the basket slides forward to empty it, I would think the safety switch is located in the front but not positive since I don't have a unit right in front of me.
Check to see if you see a slot in the top part of the shredder unit. Usually the basket has a piece of plastic that will line up with the slot when the basket is in place (Safety switch) so that the top part of the shredder knows that the basket is in place.
Look around with a flashlight, If you are going to feel around with your hand, PLEASE MAKE SURE YOU UNPLUG the shredder just to be safe.
Hope this helps.
Good luck.
Mac =)
Feb 10, 2008 | Fellowes PS-70 Shredder
Red light on will not run in forward
Check to make sure the shredder is sitting on the paper bin properly. Most shredders have a sensor switch that disables the unit if it's not properly seated on the paper bin.
Jan 21, 2008 | Office Equipment & Supplies
Top Dahle Office Equipment & Supplies Experts
jhnolson
Dennis Key
Dennis Key
Are you a Dahle Office Equipment and Supply Expert? Answer questions, earn points and help others
