Question about Panasonic KX-TG5633B Phone
Panasonic phone no link to base. Move closer to base. try again. I HAVE TRIED THESE SUGGESTIONS AND CANNOT GET A SIGNAL.
  • 2 more comments
  • Anonymous Feb 21, 2008
  • Anonymous Feb 29, 2008
    I went to use the phone today and it just started saying, No link to base. Move closer to base, try again. I tried that and nothing seems to work. What can I do to fix this problem?
  • Anonymous Mar 11, 2008
    I have teh same mesage, 'no link to base move closer' - does not work.
    I tried the reset in the manual with no results. any ideas?
  • Anonymous Nov 15, 2008
    it say no link to base move closer to base ,try again
1st) you must identify the ranking order of your handset. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset just now. Go to the main base cradle. On the bottom, where it says"locator" press the select button until you get the desired phone rank needed. H1,H2,H3 etc... Now, press and hold "call". (The charging light should start flashing) Now, on your handset press the "OK" button on the top upper right corner. Your phone should now be working! If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support.
Posted on Jan 16, 2011
A key symbol on the left hand side of the phone is blinking. I'm unble to make a call,its telling me that no link to base. move closer to base, Try again. All the phone cords are in the socks and...
The key symbol is supposed to be an antenna.
It can't receive a signal.
There are a few possibilities:
- Too far from base. Move closer.
- Base is unplugged (no power at base station)
- Phone has become unregistered (unlikely).
If you need to re-register the phone, the process will vary depending in the model of the base station and will be covered in the manual.
Apr 05, 2011 | Panasonic KX-TGA101S Cordless Handset
Both phones in the set display the message "No link to base. Move closer to base, try again." I have reviewed and implemented the troubleshooting instructions to no avail. All suggestions are...
We have a Panasonic that is starting to go stupid. After 4 or 5 years, with a fully charged battery we register it but it only stays registered for about a day or two. If yours is acting the same way, well cordless phones aren't that expensive anymore.
Mine is the cute red one.
Carl
Feb 06, 2011 | Panasonic KXTG2344 Cordless Phone
I have Panasonic KX-TG6051M cordless phone. I have been using it for years with no problems. I now get the message:"No link to base. Move closer to base, try again." I have read the user manual...
Hello! Have you re-registered the handsets? If not go to page 39...If you have re-registered the handsets...Pull the batteries for 1 hour...reinstall batteries...allow handsets to set in the cradle for 1 minute then test...
Guru...Saailer
Jan 01, 2011 | Panasonic KX-TG6051M Cordless Phone
My panasonic kx-tg4321bx didn't give connectivity response rather than it gives a message "No link to base. Move closer to base, try again"
Well, you could move closer to the base, or try this: RE REGISTER the HANDSET. That works every time when our cordless goes stupid.
Carl
Sep 30, 2010 | Lands Phones
Cordless phone not connecting to base. no dial tone.
switch the A/C mains off 5 minutes
or
Re-register them to the base,
This resolves the problem
Regards
Richard.
Apr 26, 2009 | Panasonic KX-TG5673 Trio Cordless Phone
Panasonic KX-TG2367 says "No link to base".
This worked for my mother's KX-TG2357:
We tried doing what it said in the manual on page 54. That didn't work! She then decided to just unplug everything. About 3-5 minutes later, plugged everything back in, and lo and behold, everything was working fine!!
Jan 28, 2009 | Panasonic KX-TG2357 Cordless Phone
No link to base.
unplug the base and when you plug it back in
the handset should work
Dec 13, 2008 | Panasonic KX-TG2356 Cordless Phone
No link to base move closer to base
Your getting this message because the radio portion of the handset or/and base is not communicating with each other. This can be temporary or fatal. You can try re-registering the handset(s) to the base by following the directions in the manual, its fairly easy to do for any model. If that does not work,and you have more than one handset not working with this problem, then it sounds as if your base needs repair or replacing.
Feb 04, 2008 | Panasonic KX-TG5632M Twin Cordless Phone
Move closer to base
you have to make sure that all the cable are plugged in and the power cable is plugged in too..
Dec 01, 2007 | Panasonic KX-TG6021 Cordless Phone
Panasonic KX-TG5633B Phone Logo
228 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
