Question about Frigidaire FEF336BC Electric Kitchen Range
Stove/oven not heating up after replugging in.
Replugged in the stove after replacing kitchen floor. Husband didn't shut off power first. So, there were huge sparks. The power was thrown on the house. Once we got everything back on, the stove looked okay. The clock is on, and when we turn a burner knob the light comes on. But it doesn't heat up. Same thing with the oven.
  • 11,896 Answers
Power supply is most likely burnt. It has capacitor's inside that will fry and overheat. last possible cause would be faulty control panel.
Posted on Oct 06, 2009
Hi! My old school Admiral oven/stove top is having issues. I rent, so I don't want to bother my landlord until I have to - or know what to tell him. Basically, it won't heat anything substantially. The...
You need to contact the landlord and I will tell you why: The stove should not have issues above and below simultaneously. I comment you for not wanting to bother the landlord but I feel like you have an electrical problem. The oven not there and the top not there? You have a bad circuit breaker on that puppy. Takes a 50 amp 2 pole 240 volt breaker for an electric stove and only qualified schocktricians should fool with them. My opinion.
Nov 30, 2010 | Maytag Admiral LER3330AAW / LER3330AAZ /...
My stove does not get hot enough
your oven/stove thermo-couple has gone bad and senses too much heat too soon before its actually hot and shuts off the gas supply,it is located inside the oven cavity in a clip on the top of the oven cavity and is normally replaced with the oven control dial as a calibrated unit
Jun 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
GE Profile Stove, stove top works but the oven will not heat up.
You will most likely have to replace the oven igniter. If you have the model number you posted under, I believe the igniter for the broiler is the same as the oven broiler, and could be swapped out to get the oven working again. (of course, now the broiler won't work until that igniter is replaced) If you'd like the part number or any further advise, comment back with the full model number off the sticker just behind the lower drawer panel on the frame of the range. Tonight, you may have to finish the chicken on the stove top.
Mar 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
May 15, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
Oven cuts off
turn off breaker to oven pull stove out and check incoming power supply, possible looseconnection at that point
Feb 17, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
161 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
