Question about Dell Latitude D410 Notebook
THE LID IS LOOSE AND THERE ARE NO SCREWS TO TIGHTEN ON THE HINGES
You do not need to replace the hinges, however your need to remove the font panels of the screen and laptop to remove the hinges. You will see that the pin that connects the top part of the hinge to the bottom part of the hinges has over time moved out of alignment. With pliers and a hammer manipulate the hinge pin so that it is now flush with the hinge itself. You will see that the hinge will then become tight. Then just reinstall the hinge. I just did this and I know it works.
Posted on Nov 07, 2009
  • SPC100 Nov 15, 2010
    Maverick 99 - you are the business. This fixed my screen. Now I need to unlearn my screen holding reflex.
    The bezel is the strip that has the led's underneath it. You can use your fingernail to remove the bezel. and then you will see their is a bar sticking out of your hinge. Once you manually force that bar back in, stiffness returns,.
    If you need to get the hinge off the laptop, to safely manipulate the bar, there are two screws for each hinge. one above and one blow.
  • Dell Master
  • 32,281 Answers
You are right, the fix is to replace the hinges. Check this WEB site for
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Posted on Oct 07, 2009
4 Suggested Answers
RescueTechLA
  • 2653 Answers
SOURCE: loose screen hinges
You can't. They're worn out and the way they're manufactured doesn't allow for a easy tightening unfortunately. I would pick up a new / used pair from ebay and then just swap them out.
Posted on Feb 20, 2009
SOURCE: loose hinge/lid on Dell latitude D410 laptop
I took the hinge cover off to look for myself to see if there were in fact some set screws to tighten the monitor up. None were found, no suprise there. While on ebay ordering a new hinge set I noticed that the picture of the new hinges didn;t look the same as what I observed on the laptop. The pin on the right was sticking out on my lapto but in the picture on ebay it was flush.
I used a flat ended phillips tip screwdriver and pushed the pin back in while gently rocking the monitor back and forth. That seemed to solve the problem.
Posted on Jun 14, 2010
Loose case round himges
The screws that secure the hinges to the body of the laptop may be loose. In this case tighten the screws.
If the hinges are faulty, they are not adjustable and they need to be replaced.
These WEB site can assist you to replace the hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
Feb 15, 2012 | Computers & Internet
Case loose round hinges
If the screws securing the hinges to the base of the laptop is loose then tighten these screws.
Hinges have no tightening adjustments and loose/faulty hinges need to be replaced.
These WEB sites can assist you to replace these hinges.
Feb 15, 2012 | Packard Bell Computers & Internet
One of the dryer fins is very loose. How do I tighten it?
REMOVE SCREWS FROM DOOR HINGES AND OTHER SIDE REMOVE DOOR THE FRONT DOOR CLIP REMOVE CORNER BRACKETS LIFT UP FRONT LID AND TIGHTEN SCREWS ON FINS
Jan 25, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My toilet seat is loose but there are no visible external securing parts. Its a Banyo suite with gentle self closing lid mechanism. How can I tighten it up and secure it back in place?
where the hinges sit, use a small screwdriver and prise off the top chrome cover.Under neath are the securing screws for the seat. tighten these carefully until seat is secure, then replace the covers.
May 13, 2010 | Home
Loose hinge/lid on Dell latitude D410 laptop-lid does not stay upright and falls back flat and no screws to tighten...How can you fix this? Thanks
Jan 22, 2010 | Dell Latitude D410 Notebook
Laptop hinges are loose
The hinges can be loose in two different areas, but the most popular is the hinge attachment point behind the screen bezel. Remove the rubber screw covers from the bezel, remove the screws, take your finger nailas and from the inside of the bezel pull gently to the outside to release the catches on the screen lid. Start on one side and work your way around the screen until the bezel pops loose. Look at the bottom of the screen and you will see the hinge attachment points. Tighten them up. If you have some locktite this would be a good time to apply it, remove the screws one at a time and replace. To replace the bezel, always start at the bottom and work your way up.
Jan 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
Sony VGN AR630
If the lid has a small slack and then is firmer again when the lid/screen is in another position, then the hinge mounting screws is most likely loose and the mounting screws needs to be tighten.
If the hinges are loose no matter what the position of the lid/screen is in then, they need to be replaced, there is no adjustment to tighten the hinges.
Jul 23, 2009 | Sony VAIO VGN-AR630E Notebook
How do I fix a loose lid switch?
the switch is ok loose tighten the lid hinges
Nov 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Monitor lid will not stay in position.
On most models the hinges are a pressed in, pressure brake type hinges, and when the hinge start getting worn to the point of not holding the screen, then they can only be replaced in order to fix it. You can sometimes get away with replacing just one. On some models there are screws on the hinges that come loose that can cause this. The screws aren't for adjusting, they are basically just set screws. You won't know which is the problem until you take the covers off. Most likely you're going to have to replace the hinges. Try Ebay for the replacements.
Aug 01, 2008 | Acer Aspire 5100 Notebook
Lid/Top Loose
I have a Tecra M2 S630 and was able to fix my left hinge by removing it and drilling out the rivet and replacing it with a 6-32x1/4 inch machine screw and a nut. Total cost was $4 for a package of nuts and screws from Radio Shack.
Nov 30, 2007 | Toshiba Tecra M1 Notebook
Dell Latitude D410 Notebook Logo
3,193 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
