Question about Sony Handycam DCR-PC5 Mini DV Digital Camcorder
Cassette compartment my cassette compartment on my dcr-pc5 will not attomatically open
  • walt g Jan 14, 2008
    When the case is opened the tape carrage no longer opens to give you access to the tape cassette. Therefore, I can only record over the tape over and over and never eject it to insert a blank. I've tried to do the reset feature to no avail. Please help! The Sony website helpdesk states a minimum of $311 usd to start a repair.
I had same problem. Cost me $200 to fix at local repair outfit.
Posted on Jun 19, 2008
I have a sony cassette handycam. After inserting the cassette the compartment does not close,The cassette is not pulled in to go back to its place.Tel me the solution thanks
The mechanism of the cassette compartment is misaligned and it need mechanical adjustment, Please contact any repair man nearby to resolve the issue, No part is required in mechanical adjustment.
Thanks
May 14, 2011 | Sony Handycam DCR-TRV103 Digital Camcorder
Condensation moisture error icon (tear drop) on for some time, I do not think I have ever had a real condensation or moisture issue but have let the camera dry for weeks, error still appears, can you help...
Blow into the cassette compartment with a hair dryer , do not use too much heat but just to warm up. The dew sensor is fitted near to the drum assembly. this is to prevent the tape being chewed up if there is condensation. The dew switch can go defective inmany cases and can be destabilised. so if after heating the fault changes you can find this small black piece of a conducting medium exposed. Remove the solder of one side and check.
Sep 18, 2010 | Sony Handycam DCR-PC5 Mini DV Digital...
I need to down load drivers of mini DV sony DCR-PC5E
  1. look at manufactuers website
  2. look on google (not recommended
Aug 10, 2010 | Sony Handycam DCR-PC5 Mini DV Digital...
Dcr pc5 camera to computer connection
Your PC5 should have FireWire as standard, but Sony use a smaller 4 pin connector which looks a little bit like the tiny USB connectors on modern phones and still cameras. The main difference between the 4 pin and the standard FW400 6 pin, is no power is supplied to the 4 pin, so the camera must be powered from the internal battery or an external supply
The original Imacs came with such a cable, but you can buy these from various suppliers. It's part number F3N401-06 from Belkin or M8706G from Apple
Dec 29, 2009 | Sony Handycam DCR-PC5 Mini DV Digital...
Connect Sony Handycam DCR-PC5 Mini DV Digital Camcorder to my Laptop
try to install the cd software of your sony handycam into your laptop..
hope it will help thanks...
May 27, 2008 | Sony Handycam DCR-PC5 Mini DV Digital...
Sony Handycam DCR-TRV19E Pal do not eject tape
I think, your camera requires new DV Mechanism replacement.
May 08, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-PC5
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Jan 12, 2008 | Sony Handycam DCR-PC5 Mini DV Digital...
Cassette compartment do not pop out
Smack the camera smartly on the tape side. Bet it works.
Jan 09, 2008 | Sony Handycam CCD-TRV43 Camcorder
Sony Handycam DCR-PC5 Mini DV Digital Camcorder Logo
213 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
