Question about Whirlpool LGR3624JQ Gas Dryer
When I start the dryer in either auto or timer mode the burner starts and the heat comes on. It will run for awhile with heat and then the burner will shut off. The dryer continues to spin but no heat is being put in. I replaced the high limit thermostat and the operating stat. The thermal non resetable fuse is okay.
    President:
  • 744 Answers
With the limited information you gave I will assume this is a gas dryer that the flame starts for a minute or so and then shuts off. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils When I start the dryer in either auto or timer - 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Posted on Oct 06, 2009
Testimonial: "Yes this was the problem. Thank You vedry much. Replaced both coils. Strange thing is the new and old read the same resistance."
On my kenmore dryer 970-c82062-00 I can get all 3 timers to start but the heated automatic dry portion does not time out.
that model number doesn't come up,you sure that isn't the serial number?also does the dryer have heat,when you run it on time dry the timer just counts down like a clock,when on auto or more or less the heat comes on until the dryer heats to temp. the heat shuts off and the timer will advance,when the heat comes back on the timer stops moving,it will do this until the clothes are dry,if you do have heat you could have a bad sensor or a bad cycling thermostat but you'll have to check it with a meter.send the model number and i can help you better.
Feb 16, 2014 | Dryers
Dryer runs with no heat and never shuts off on its own
what are you running it on?auto or more or less,if so the timer will not advance to off without heat,usually the heat comes on,the dryer heats up until it reaches temp.the heater shuts off and then the timer will start to advance to off,when the heat comes back on the timer will stop advancing and the heat will come on,it will do this until the clothes are dry,so no heat the timer will not move,now if you put it on time dry the timer should count down no matter what just like a clock.if you open the door and look around the opening where you put the clothes in you'll see a tag with the model number send this and i can help you.
Oct 08, 2013 | Kenmore 63942 Dryer
Amana lga30aw. dryer starts in auto mode, pilot on, gas on, goes off after awhile and never comes back on. timer does not move in auto but does move on the timed mode (still does not dry in the timed...
You may need to replace the timer, but watch the video below and it will walk you thru the troubleshooting process. The timer not moving in the "auto sense" mode maybe due to a bad thermostat. Here is a link to the timer in case you need it.
Jan 05, 2011 | Amana ALG331RAW Gas Dryer
The dryer runs but no heat. The igniter glows when you start the dryer for about 10-20 seconds then goes out but the gas never ignites. I have tried bypassing the high limit fuse in the vent and have...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 11, 2010 | Roper RGX4634KQ Gas Dryer
When I start my dryer, I have heat at first, but it shuts off after a short time for the rest if the cycle.
It sounds like you have a gas dryer . The coils on the burner valve need to be replaced . They get hot from the electricity going thru them , and one opens (shorts ) until the dryer cools down . It should then heat again for a few minuted , then stop heating but still run . Your timer will not advance either , if set on auto , unless dryer heats . Without the model number , cannot give you the part number , so take it with you to get the part . It comes with both coils in a pkg .
Oct 11, 2009 | Whirlpool Dryers
Whirlpool Gas Dryer LGR7646JQ1 Auto Setting Does Not work
I am thinking the timer has gone bad, They tend to work in some spots, and not others , when they fail. If you can put the dryer in Auto mode, then nudge the timer until you hear the burner light, see if it continues from there. If it does, chances are pretty good it's the timer.
Jan 27, 2009 | Whirlpool LGR7646E Dryer
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
Maytag gas dryer model # SDG305DAWW
replace the coils atop the burner assy itself, part number 279834..
Dec 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
Whirlpool LGR4634JQ1
Check for a restricted vent. Clean vent and check for kinks. Make sure lint screen is clean. If you do-not have good airflow due to a restriction, the burner will not stay on. It's a safety thing.
Nov 18, 2007 | Whirlpool LER5636P Electric Dryer
Whirlpool LGR3624JQ Gas Dryer Logo
159 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
