Question about Car Audio & Video
My calibra amp lit the red power led (to show protection )now my subwoofer won't play
  • 117 Answers
Disconnect sub woofer , amp may reset and light will be steady , if so replace wireing to sub and sub its bad
Posted on Nov 25, 2009
I have 2 15 inch kicker l7s duel 2 ohm in a built to specs slot port i need an amp that will power them what should i get
this guy know jl amps are ONLY 1.5 - 4 ohm stable? won`t 1 ohm send amp into protection with thermal indicator lit up like the northern star?
Sep 26, 2012 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
Kicker 250.2 amp, I have green power led, but the red led on top of the unit does not come on, nor does the red protection led, hear a click out of the subs on occation but nothing else, looked inside and...
Sometimes clicking, or popping sounds from subs are caused by over excursion of the subwoofer, wich can be caused by ultra low frequency, or going below the tuned frequency of your enclosure.
Aug 12, 2009 | Car Audio & Video
Amplifier Problem
never ask geeksquad about amps lol check your ground wire connection and push on sub do you feel scratching if so its blown sub also never turn an amp up all the way it starts pushin dc voltage witch a 200 watt amp can blow a 800 watt sub dc voltage is not good for subs also up all the way can burn out the internal battery in the amp lets hope thats not it just make sure ground is good protection light means that the amp has power but a connection is not bien made sum where to complete the circut
Apr 12, 2009 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
New Dual XIA3145 2/1 LED glows red, guide claims speaker problem
look at these and only these... power or ground...either your power wire has grounded out somewhere (ud be surprised) or youdont have a good enough ground....i would check the ground first....hopefully this helps
Jan 27, 2009 | Dual (DBXPA6100) Car Audio Amplifier
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Hi i am matt
If the protection LED lights only after the remote voltage is applied (head unit is switched on), the amplifier likely has shorted output transistors. If the protection LED remains lit without remote voltage applied, the amp may have other problems.
Does the protection LED light with no speaker wires connected to the amp and no RCAs plugged into the amp?
Jun 22, 2008 | Car Audio & Video
My amp is on but the protection light stay's on!!
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
Feb 28, 2008 | AudioBahn A2801Q Car Audio Amplifier
Power and led on but yet no sound
red means protect, check speakers first then disconnect all power,try again in 20 min
Aug 22, 2007 | Visonik V900XD Car Audio Amplifier
Car Audio & Video Logo
305 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
