Question about Saeco Royal Professional Espresso Machine
How do I check how many coffees we have made on our Saeco Royal Professional coffee machine
  • 1,089 Answers
Hi
Push and hold the menu button. When is says "energy saving" use the up arrow and go up about 3 or 4 pushes until you get the * beside the "total coffee", then push the menu button again. The menu button is what gets you into the selections and is what locks changes in the computer.
Posted on Oct 07, 2009
JohnnyBeans
  • 223 Answers
SOURCE: my Saeco Royal Professional
Okay! This can be 1 of 2 things.
1. Your machine button needs to be programmed. Do this by holding the button down until the coffee is dispensed to the height of your likeing, then let go. The button should now be programmed.
2. Your machine is leaking internally and some of the water that should be going into your cup is going elsewhere.
Also try descaling your machine. For more info go to: www.cerinicoffee.com
Posted on Oct 12, 2007
  • 3 Answers
SOURCE: saeco royal professional coffee machine
run the hot button a few times
Posted on May 26, 2008
EsWorld
  • 1618 Answers
SOURCE: No water coming from Saeco Royal Professional Coffee Machine
Check the end of the steam spout using a paperclip make sure it is not blocked.
  • 1089 Answers
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Posted on Jun 14, 2010
  • 1089 Answers
SOURCE: I have a Saeco Royal Professional at work and when
Hi
Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter.
Posted on Apr 07, 2011
Saeco royal professional machine started giving half cup less coffee then normall
Do you know how to reset the amount of the cup amount. I have a different saeco model but this mite help. Press the button for a coffee and keep it pressed in this is how you reset the level on mine when you release the button it resets the level.
Nov 09, 2013 | Saeco Coffee Makers & Espresso Machines
I have a Saeco Royal Professional at work and when each of the three coffee size buttons are pressed you get three different sized coffees. I have just bought a new Saeco Royal professional for home and...
Hi
Apr 05, 2011 | Saeco Royal Professional Espresso Machine
SAECO fully auto Traditional Very little crema
The crema is created by reducing the grinding to more fine so the coffee will run slower around 20 sec. Inside the coffee bean container their is un adjust control and with special tool you can turn it to grind the coffee to more fine.
Jan 03, 2010 | Saeco Royal Professional Espresso Machine
Oct 06, 2009 | Coffee Makers & Espresso Machines
Can you buy a repair manuel for a saeco royal
www.manualnguide.com/.../manual.../saeco-royal-professional-instruction-manual.html -try tis link
Jul 23, 2009 | Saeco Royal Coffee Bar Coffee Maker,...
Saeco Royal Professional Coffee ends up in the bin not into the cups. What has happened and where can I go to resolve it. Thanks Mala
If you mean the Coffee Seems to end up all around your brew unit, a common fix is to move the dosage control (this is the slide on the right hand side of your machine just above the door to the brew unit) back and forth repetitivly.
Try this
Paul
Saeco Coffee Machines
Aug 18, 2008 | Saeco Royal Professional Espresso Machine
Coffee Grounds
I would try cleaning out your coffee grinder first.
Here is the link to some helpful documents: http://www.cerinicoffee.com/Saeco_technical_documents.asp
Espresso machines and cleaning supplies
Visit www.CeriniCoffee.com
Mar 15, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
156 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
