Question about HP PSC 2110 All-In-One InkJet Printer
I have cleared a cartridge jam but machine keeps telling me to remover back door and clear jam
Printer will not print because it thinks it has a cartridge jam. The is nothing jamed in the printer.
I don't have driver
Posted on Jan 10, 2008
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
LOCATION OF PRINTER SENSOR
Jams
Clearing jams
CAUTION Do not use sharp objects, such as tweezers or needle nose pliers, to remove jams.
Damage caused by sharp objects will not be covered by the warranty.
CAUTION Always pull jammed media in the direction it would travel through the paper path.
Do not pull jammed media against the direction of travel through the paper path to avoid damage
to the printer.
To prevent damage to the printer when clearing jams, including jams in the output bin, always open the
print-cartridge door and remove the print cartridge. Keep the door open and the cartridge out until the
jam has been cleared. Opening the print-cartridge door and removing the print cartridge relieves tension
on the printer rollers, which prevents damage to the printer and makes the removal of jammed pages
easier.
Occasionally, media becomes jammed during a print job. You are notified of a media jam by an error
from the software and the printer control panel lights. See Control-panel lights (HP LaserJet 1010 series
printers) on page 102 or Control-panel lights (HP LaserJet 1020 printer) on page 106.
The following are some of the causes of media jams:
The input trays are loaded improperly or are too full. See Loading media on page 25.
NOTE When you add new media, always remove all of the media from the input tray and
straighten the stack of new media. This helps prevent multiple sheets of media from feeding
through the printer at one time, reducing media jams.
The media does not meet HP specifications. See Media specifications on page 21.
Typical media jam locations
Print cartridge area: See Removing a jammed page on page 43.
Input tray area: If the page is still sticking out of the input tray, gently try to remove it from the input
tray without tearing the page. If you feel resistance, see Removing a jammed page on page 43.
Output path: If the page is sticking out of the output bin, see Removing a jammed page
NOTE There might be loose toner in the printer after a media jam. This toner clears up after
a few sheets are printed.
Use the procedures in this section to remove a jam.
CAUTION Media jams might result in loose toner on the page. If you get any toner on your
clothes, wash them in cold water. Hot water will permanently set the toner into the fabric.
Partshere Troubleshooting
CAUTION To prevent damage to the printer when clearing jams, including jams in the output
bin, always open the print cartridge door and remove the print cartridge.
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print
cartridge with a sheet of paper.
NOTE The following illustrations show the HP LaserJet 1020 printer. The same procedure is
used to remove a jam in the HP LaserJet 1010 series printers.
Open the print cartridge door, and remove the print cartridge.
Grasp the middle edge of the side of the media that is most visible, and carefully pull it free from
the printer.
jams. Damage caused by sharp objects will not be covered by the warranty.
Do not forcefully pull jammed media against the direction of travel through the paper path to
avoid damage to the printer.
When you have removed the jammed media, replace the print cartridge, and close the print cartridge
door.
After clearing a media jam, you might need to turn the printer off then on again.
NOTE When you add new media, remove all of the media from the input tray and straighten
Sep 25, 2011 | HP LaserJet 1020 Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
Copier makes a noise when first turned on and then it tells me to open the door clear carriage jam and press enter. But that does not work. The printer has been sitting for a little...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Nov 29, 2010 | HP PSC 1600 InkJet Printer
My printer comes up with a clear paper jam and press checked key. I have cleared all paper from machine and yet the light flashes and will not allow me to print and the same error code comes up. What...
Solution one: Turn the All-in-One off and on again Follow these steps to turn the product on, and then off again, to reset the print mechanism.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn the product on again.
    NOTE: The product might go through a warm-up period of up to two minutes. The product lights might flash and the carriage might move. Wait until the warm-up period is complete before proceeding.
  4. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again.
  • If the issue persists , continue with the next solution.
  • If the self-test report does not print , continue with the next solution.
Solution two: Clear any paper jam Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose paper from the input tray and output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear a paper jam from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the back of the All-in-One Use the following steps to check for and remove jammed paper from the back of the product.
  2. Disconnect the USB or Ethernet cable from the back of the product.
  3. Disconnect the power cord from the back of the product.
  4. Remove the rear door. Push the door latches toward each other, and then pull the door away from the product. Figure 1: Remove the rear door c00244379.gif Illustration of removing the rear door
  5. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. If you are printing labels, see if any are missing from the label sheet. If any labels are missing, find them inside the product, and then remove them carefully.
  7. Reattach the rear door. Gently push the door forward until it snaps into place.
Step three: Clear the paper jam from the front of the product Follow these steps to remove the paper jam from the front of the product.
  1. Open the cartridge access door. Figure 2: Open the cartridge access door c01913998.gif Illustration of opening the cartridge access door
  2. If you find paper jammed in the product that cannot be removed through the rear door, gently remove the paper through the front of the product.
    NOTE: Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism.
  3. Close the cartridge access door. Figure 3: Close the cartridge access door c01913999.gif Illustration of closing the cartridge access door
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01602202.gif ) to turn on the product.
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Keep in this LINK.
Oct 26, 2010 | Dell 948 All-In-One InkJet Printer
False paper jam reading.keeps say to clear paperjam. called HP and they said its a common problem,too expensive to fix,buya new one from us for 300 bucks
Check the following Steps for fix HP printer carriage Jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Sep 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Phantom Paper Jam
There may be a problem with the fuser unit. First check all the doors and drawers for paper jams, including removing the toner cartridge and looking inside. Leave the cartridge out, turn off your machine, unplug for 1 minute, then turn back on. Close door without the cartridge inside. Machine should tell you to insert cartridge. Put it back in, and see what it does. If a simple reset like i have described does not solve the problem, there may be a small piece of torn paper somewhere, or a sensor may be broken or dirty. Please reply with the results!
May 07, 2009 | IBM Infoprint 32 Laser Printer
Paper Jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Sep 21, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Paper jam cleared - but still won't work
turn off the printer for a while then back on again, if it still refuse to print, try printing a test page.
Feb 13, 2007 | Canon LBP 800 Laser Printer
HP PSC 2110 All-In-One InkJet Printer Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
