Question about Samsung HCM4215W 42" Rear Projection Television
Tv will not turn on, when you press the power button on either the remote or the tv set itself you hear it power up inside but get no picture then the light next to the power button begins to blink
I have one I just got that has the same issue.. Does anyone have a recommendation of where to begin regarding this problem>???
Posted on Jan 19, 2010
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
Restore Sony KDL32L5000 to factory defaults
• Check the input selection by pressing the INPUT button. You may be watching the wrong input.
• If you cannot hear sound from the TV, you may have accidentally pressed the MUTING button on your
remote control; press the MUTING button again or press VOL + to deactivate muting.
• If the remote control is not functioning properly, the batteries may be installed incorrectly or may be low or
an object or light may be interfering with the remote control.
• To reset the TV to factory default settings:
1 Turn on the TV.
2 Press and hold down the V button on the remote, press the POWER button on the TV set. (The TV
will turn itself off, then back on again.)
3 Release the V button when the TV is turn on.
WARNING: The factory reset will clear all of your customized settings including the Parental Lock setting.
When the Password is lost or cannot remember, enter the master password: 4357. This password clears your
previous password and allows you to enter a new password.
Jul 08, 2012 | Sony KDL32L5000 32 in. LCD HDTV
My 52 ince screen stopped showing picture. It is just red, or yellow or green with thin vertical lines. I can hear that the channels are changing but no picture. Is there a reset button or something?
To reset the tv to factory/ default settings, please follow below procedure.
Turn On the TV, while holding down Up Arrow on the remote control, press Power button on TV, tv will turn itself Off then back On again, release Up Arrow on remote control.
This procedure will reset all settings in tv to default settings.
Problem seems with lcd panel and I'm afraid it does not seems to get solved by resetting tv however try to reset tv by above said procedure.
Thanks.
Aug 04, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Jun 15, 2011 | Samsung TXP2036 20" TV
My mothers 19" Aquos tv
Hi
If your tv or your mothers tv actually, is the selected LC-20B4u-S model. Then instructions below, if not post me the correct model.
1. press menu to display the menu screen.
2. press up or down to move the cursor to video adjust and press enter
3. press up or down to move the cursor to the RESET
4. press enter to reset.
if that doesn't help try
Power on the television. The Sony TV has to be on to start the operation.
Press and hold the up arrow on the remote.
Make sure that the remote is facing the television and is not obstructed.
Press the power button on the Sony TV.
Press the button on the television itself, not the power button on the remote. You can release the up arrow after you press the power button. The television will power off and then power itself back on with all of the settings reset to their original factory defaults.
If that doesn't work keep holding the up arrow unti ti power off and back on.
Dec 16, 2010 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
There is shadows on the insdide of the screen
Turn your TV on by pushing either the power button on the front of the TV or the power button on the remote control, which is located in the upper right corner of the remote.
Step 2
Press and hold the "up arrow" button on the remote control. The up arrow button is located in the middle of the remote, to the left of the "Input" button and below the "Picture" button.
Step 3
Press the power button on the TV while still holding down the up arrow button. The TV will turn off and then turn itself back on.
Step 4
Release the up arrow button. Once the TV turns itself back on, it will restore your TV to its factory settings.
Hope this helpout.......
Aug 03, 2010 | Televison & Video
How do i reboot my konka television?
Step 2
Step 3
Step 4
Release the up arrow button. Once the TV turns itself back on, it will restore your TV its factory settings.
Aug 03, 2010 | Konka KDL32AT23U 32 in. LCD Television
Modified Picture Settings Reset Each Time TV Is Turned Off/On
Your TV may have been put into shop mode or demo mode. How to get out of "Shop Mode"
1. Press [Source] to get to the Air or Cable input on the TV or TV remote
2. Press [Volume +] once on the TV itself (not the remote)
Next step must be completed while the volume bar is still on screen
3. Press and hold [Menu] on the TV itself (not the remote) for about 7 seconds
If the screen flashes "Dynamic Mode", the process worked
4. Finally check whether the Picture Mode is "Shop Mode" or not after passing "INFO" on Remote Control. If picture mode is still in “Shop Mode” try the alternative way below
Alternative Method
Press [Source] on TV remote to get to the AIR or CABLE input
Press [Menu]
Press [Down Arrow] to highlight SETUP and press [Enter]
Press [Enter] again on PLUG AND PLAY
Wait 10 seconds
Press [Enter] to select ENGLISH (or choose an alternative language
Press [Right Arrow] to highlight HOME and press [Enter]
Press [Menu] repeatedly until you see the message ENJOY YOUR WATCHING
Confirm you are out of shop mode by pressing [Info] on the TV remote
Nov 09, 2008 | Samsung HL-T5687S Television
ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
Jan 27, 2008 | ESA ET413E 13" TV
My tv will not turn on.
First of all, forget about the remote and see if the TV functions normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has either gone bad or was accidently set to a different brand. In this case, look for the original book that came with the remote (or TV if it is the original remote) and follow the instructions for setting the remote back to Zenith. Try that and post your results here.
Aug 09, 2007 | Zenith C27A24T 27" TV
Samsung HCM4215W 42" Rear Projection Television Logo
184 people viewed this question
Henry  Thomas
Henry Thomas
