Question about Nokia N81 Smartphone
Nokia n81 wont send texts formatted hard drive in phone memory changed to phone memory downloaded and updated latest software still wont send texts saying memory is full.????
  • 217 Answers
Back up your files,then perform a manual format by typing on your phone.*#7780# or *#7370# and type the security code prompted in your screen and wait until rebooting completely done.and try to make a text and send it.enjoy...........
Posted on Oct 07, 2009
  • Joey Nyirenda Jul 10, 2013
    Nokia X2-The problem has'nt gone
  • Gil Domanillo
    Gil Domanillo Jul 11, 2013
    Try to flash or upgrade your firmware to the newest firmware using nokia PC suite..
I formatted my phone, and it still wont send texts?
Try flashing your phone. Install NOKIA PC SUITE and NOKIA SOFTWARE UPDATER (google them and select them from the Nokia websites) on yourt computer. Then connect your phone via the USB cable. Once the Nokia PC Suite finds and instal your phone, then run the Updater. It should allow you to install a higher version or the same version of your software. If you like to keep your data, you can use the nokia PC Suite to back up your entire phone before running the Software Updater. Afterwards use the same to Restore your Data.
Make sure your phone is fully charged before doing this.
Jun 24, 2009 | Nokia N95 Cellular Phone
Nokia N81 Wont send SMS
i had da exact same prob so i format my cell now its working jus fine so i would suggest formatting the set !!!
Jun 08, 2009 | Nokia N81 Smartphone
My hand set NOKIA N 81, I'm not use my mobile camera. when i press camera button, then this TEXT will be show. CAMERA FEATUER NOT SUPPORTED
it is a software problem it seems like just hard reset ur device like this if it doesnt help then pls update ur Phone Rom from www.nokia.com
downlaod the software update utility from nokia and then connect the internet and update ur ROM thru cable supplied with phone u will get all software for backup and drivers from the nokia website
pls first hard reset like this if it helps PLS RATE ME FIXYA for help !
Master reset
1) *#7370#, then enter 12345 (This is the default security code unless the user has changed it) and then Yes. The phone then wipes all apps and phonebook contacts on the internal memory.
if it doesnt work then try this to hard reset
switching off the phone then press and hold Call key (Green key) + * key + 3 key + power button for a couple of seconds
pls let me know of the results and do rate me well if i helped u
May 04, 2009 | Nokia N81
Wont send text. says memory full
Hi
there was a common software fault on this model. Try a factory reset, but back up your information first! If this does not resolve the issue, do you still have Nokia Data Suite software that came in box with the phone? Load this disc into your computer and using the data cable supplied also with the phone, connect to the Data Suite software. In the Data Suite program is an option to update the phones software to latest version from Nokia. (back up you information first as software update will wipe your data!)
Otherwise if phone is still under warranty return to where you purchased who should be able to update software for you free of charge? Hope that helps?
May 02, 2009 | Nokia N95 Cellular Phone
Phone beeps, applications shutdown automatically
ok try reset the phone first like this enter following code
*#7370# .......... Format phone
*#7780# .......... Factory Reset
password try 12345 or 00000
if u are unable to enter number as u said earlier then pls update ur phone software from www.nokia.com select ur region and ur phone from list then download software update application backup ur data if it lets u do it and then download the phone software and update ur phone with latest software everything will be ok otheriwise it a hardware problem i can guide u further if u want me to
pls rate me FIXYA for help
Mar 31, 2009 | Nokia N81
Nokia N 81 when I turn on my camera it says.
ok try to reset the phone first like this enter following code
password try 12345 or 00000 or 1234 or 0000
if problem persists then pls update ur phone software from www.nokia.com select ur region and ur phone from list then download software update application backup ur data if it lets u do it and then download the phone software and update ur phone with latest software everything will be ok otheriwise it a hardware problem i can guide u further if u want me to
Mar 29, 2009 | Nokia N81
When i turn on my n81 the lights turns on and the nokia word comes out..and that's it and it ends there...how can i fix it?
Mar 17, 2009 | Nokia N81
Nokia n81 8gb camera feature not supported?
This problem is due to the missing of phone's system files.You can solve this problem either by updating or re-installing your phone's software.
Feb 12, 2009 | Nokia N81 Smartphone
Software update problem of nokia N81
Try to do a hard reset again.
Just type: *#7370#
This will delete all data in the phone!!!!
Jan 09, 2009 | Nokia N81
Nokia n81 8G
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.
or try this(But it will fully format your phone)
Method 1:
Three Finger Reset for Nokia Phone
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
Hard Format of Nokia Mobile Phone
2. Now Press following key-*#7370#
3. Enter Default lock code is 12345.
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Soft Reset of Nokia Mobile Phone
1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
Jun 02, 2008 | Nokia N81 Smartphone
Nokia N81 Smartphone Logo
214 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
