Question about Radio Shack Cinego D-1000 Multimedia Projector
Adjusting the angle of my cinego?
Im trying to mount the cinego in the ceiling im having trouble with my image it looks like its projecting at a angle the bottoms all wedged out. Is there a way to adjust the image so that I can leave it in the ceiling? contact me at duncan1473@yahoo.com
  • pointzero00 Oct 29, 2008
    Can the Cinego d 1000 be ceiling mounted upside down??
  • gchapelas Jan 11, 2009
    projector is a couple of degrees off center to the side, but the picture is not square. I've tried keystone, but still not squaring
If you go into the setup menu you will find an option called keystone. You can adjust that up or down until it looks right to you. What it actually does is project an angle image that will look like a square image when it is projected down from your ceiling.
Posted on Jan 10, 2008
How can a flush mount fan be leveled if the ceiling is at an angle?
Flush mount fans are made for Flat ceilings. They are also a waste of money! You won't get any airflow,
Jul 20, 2013 | Minka Aire Ceiling Fan
My image is upside down after I mounted my projector to the ceiling
There are projection mode settings which will allow you to adjust the orientation of the image. Adjusting this setting will rotate the image so that it is not displayed upside down when attaching the projector to the ceiling.
To activate this setting:
  1. Press the Menu button on the projector.
  2. Using the Arrow buttons, select the Image icon on the left side.
  3. On the Image screen under the Projection label, select the icon that represents ceiling mounted projection. Note: You may see both front and rear ceiling mounted projection modes. You may choose which ever best suits your needs.
  4. Press Menu on the projector controls to exit the settings menu.
Nov 19, 2011 | Office Equipment & Supplies
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
Turning it back to normal after ceiling mount for LP755
hi,
1. perss menu button
2. select controls
3. then select ceiling projecton (When you turn Ceiling Projection on, the projector turns the image upside down for ceiling-mounted projection. Highlight Ceiling Projection, then click either button to select turn this feature on and off.)
ok
Dec 21, 2010 | InFocus LP 755 Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
I have a sony projector ceiling mounted, the image is projected
go into the menu and the image settings. there is a selection for front, rear, ceiling front, and ceiling rear. it might be sent to ceiling rear, so change it to ceiling front.
Dec 15, 2009 | InFocus In2102 Projector
Casting image lower on wall
I don't know the model number for your projector, but most projectors are designed to place the image level with the bottom of the projector, which works great for tabletop mounting but not so great for ceiling mounts.
If you're mounted at ceiling height, try turning the projector upside down to see if it places the image in the right place on your screen. If that fixes it, then use the on-screen menus for your projector to flip the image and you should be all set.
Dec 09, 2009 | Dell Office Equipment & Supplies
Mounting the Projector from the Ceiling
Projectors, in general want to project the bottom of the image 1 foot above the lens at a typical range. When mounted upside down, they project the top of the image 1 foot below the center of the lens. If you don't want to turn the projector over, you'll have to change the angle and probably go to the extreme on the keystone correction.
Aug 05, 2009 | Dell 1200MP DLP Projector
Remove screen on MTX HT625AC ceiling speaker
as far as i know the tweeter is angled in the mount it does not look like the speaker can be angled as it appears to be fairly standard ceiling unit.
but the cover looks like a push on so maybe very careful levering might work.
Apr 20, 2008 | MTX HT625AC Speaker
Angle of projected image
Hi there
No this can not be changed , the PB6100 was actually designed to mounted upside down in your ceiling and therefore the lens is 28-30 degrees upwards when projected on a flat surface.
Flip it upside down and you'll see what I'm getting at.
Oct 07, 2007 | BenQ PB6100 Multimedia Projector
183 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
