Question about Crosley Washing Machines
Drum won't spin - Crosley Washing Machines
  • 8,404 Answers
Probable broken belt
Posted on Oct 06, 2009
The clutch is super hard to turn. Is this why my machine won't spin?
if the clutch is locked ... or tight... then the drum would be more likely to not STOP turning...
If the clutch were loose then the drum would not engage with the motor...what brand , make model serial number?
Apr 17, 2013 | Washing Machines
Dryer won't spin
Was the belt shredded ( normal wear & tear ) or burnt through which could be a drum bearing or support problem .What does the drum feel like when you turn it by hand is it grinding & lump ? The fact that the motor runs with no load could by the start device faulty these are reasonably cheap to replace this is the small cylinder attached to the side of the motor with two wire connections . if your motor has not got one of these then its the start windings in the motor
Jan 11, 2013 | Maytag Dryers
Large loads won't balance & spin
Could be:
1. Broken spring(unlikely)
2. Bad shock absorbers (maybe)
3. Broken spyder-the Inner drum part that holds the drum to the hub(kinda likely). If inner drum can be moved without outer tub also moving in tandem, then broken spyder is likely.
Good luck
Mar 06, 2018 | LG WM2301HW Front Load Washer
Clutch drum won't spin with clutch
look for a broken pin between the two parts
Mar 26, 2012 | Garden
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
Washing Machines Logo
16 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
