Will not drain and spin out water i turn the dial to drain and the spinning begins but the water is not emptying into the sink from the rubber drain hose.
    President:
  • 1,304 Answers
Well i would have to say its your pump
its either bad or clogged
but i dont have a model number to be more specific
Posted on Oct 06, 2009
Why has my machine not drained or Spun.
Cant be 100% but could be overloaded, turn off, set dial / program to spin and try again, may need several goes to empty.
Jan 13, 2016 | Washing Machines
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
When time to drain pump drains water then just hums and it wont spin, get error code f01. when i turn dial to drain and spin pump just hums drum might turn a little but it never spins. i have emptied...
f01 is main controller (board) failure.
Replacing it is the only solution.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer drum doesn't spin, no draining of liquid
If you have got rid of all the water, and it still will not spin, then the odds are it is the brushes in the motor that need replacing.
Quite a common problem
Jan 18, 2010 | Bosch Axxis WFL 2060 Front Load Washer
What is a ld error code? It will not spin when it is supposed to spin fast. This is the error code that comes up.
LD is the error when it takes longer than 5 minutes to drain the water out and reset the sensor. Press pause/cancel twice to clear. The washer will begin a slow spin, and when the motor allows, increase the spin speed towards the spin speed selected. Depending on the model, it will make several attempts, each time pulling water off of the load at the slower speed. If it cannot "get permission" to increase to it's selected speed within the allotted tome, it ends the cycle and the error code "LD" is displayed. Usually two common things can contribute to the DL alarm. One is the strainer, and the other is the drain line. The strainer is in line between the drum and the pump. On a front loader, it is behind the kick panel below the front main panel. It is connected to the drum with a rubber hose and strains the water going to the pump. Clean the strainer, and, while it is open, look inti the pump cavity. Remove any debris that you find there. Reassemble the strainer.
Anything that gets by the strainer and pump will eventually pass through the drain line and on out through the house drain. Empty the drain hose into a bucket to help displace any sediment and debris in the line. If possible, run an empty cycle with the drain hose pointed outside.
Best regards, --W/D--
Aug 13, 2009 | Kenmore Washing Machines
Smelly drain and wont spin properly
check filter may need pump then flush through on hot wash.
Jun 29, 2009 | Washing Machines
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
