Question about Whirlpool Duet GHW9150P Front Load Washer
I need to know how much water in litres its uses per cycle
    President:
  • 1,304 Answers
14-17 gals total including extra rinse
or 14 x 3 42 liters approx i dont do metrics realy
Posted on Oct 06, 2009
4 Suggested Answers
  • 1462 Answers
SOURCE: Water usage per cylce
water usage is about right. top loaders use far more and so does hand washing
only way there would be excessive water usage is if machine were overfilling
Posted on Aug 13, 2008
hiltonjug
  • 612 Answers
SOURCE: wter usage per load/cycle
When set on large load, it will use close to 30 gallons of water. On the smallest load setting, it will use right around 20 gallons. This is what makes the new front load washers look so good. They average around 4 - 6 gallons per load. Have a great day.
Posted on Oct 18, 2009
  • 6277 Answers
SOURCE: Please provide the water usage
You are not actually talking to any particular manufacturer but a FixYa forum so sorry, I doubt whether anyone on this forum would have access to such detail about one particular model;-0(
The forum is just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web. Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
Have a look at the manufacturer's panel, probably on the back- it might give you an indication there- or your manual?
Another possibility would be to go onto the manufacturer's web site DIRECT to see OR your (intended) vendor's site.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Aug 22, 2011
Have a Hobart ecomax 452/502 dishwasher.. using too much auto liquid.... about 4 litres a day...
Remove the auto liquid , replace with water.
Start a washing cycle, wait two minutes till you hear the water filling inside. Open the door and pour a litre or so of Vinegar inside the machine. Let the rest of the cycle run.
This should clean out the inside of the machine if its not too bad. Otherwise you will have to find the "chemical sensor" and mechanically clean whatever is stopping it from sensing the water. It usually looks like two pencil ends about an inch apart.
If your machine looks "white" inside when its dry (from hard water) you might need a stronger cleaner than vinegar, or just try using two litres.
Apr 05, 2017 | Hobart Dishwashers
What is the ratio of water for roundup?
what does the size of the round up container say ?
it depends on what you want to get rid of. Weedy plants, vines , broad leaf plants need more round up guess 80 ml per litre.
Grass 20 - 35 ml per litre
However it really depends on the round up as some round up is a higher concentration and then you need less roundup to water
May 07, 2016 | Garden
What is 20:1 ratio of two cycle oil per gal
One part oil twenty parts petrol to a gallon 8fl oz per gallon it may be easier in litres 5 litre is one gallen nearly so add 250ml to the gallon it will run fine hope this helps
Jul 24, 2014 | Garden
How to compute kilometers per litre
You would fill up the vehicle, then divide the mileage traveled by the amount of fuel it took to fill the tank again.
So assuming you filled the tank each time, you would divide 609km by 100.4 ltr which is .1648 or 16.49 L/100km
Thats about 40 mpg.
Jun 27, 2013 | Cars & Trucks
I need to know the fuel/oil mix ratio for a bolen bl 100 31cc trimmer.
You should use 3.2 fl oz of 2 cycle oil for every one gallon of unleaded gas or 100 ml per 4 litres of gas.
Apr 28, 2011 | Garden
Weight of 8 litres in pounds
You can't convert litres to pounds, at least not directly. The litre is a volume measurement, not one of weight (mass, actually). A litre of one material may not have the same mass as a litre of a different material, so a simple conversion factor doesn't exist.
If you know the specific gravity of the material you want to measure, you can convert the volume to a weight. Water is defined to have a specific gravity of 1.0, and 1L of water = 1 kg. One kilogram is approximately 2.2 pounds (you can look up the conversion factor if you need more accuracy). So if you are dealing with water, 8 L is around 17.6 pounds.
If you aren't measuring water, find the specific gravity of your material, and multiply by that value. A liquid with a specific gravity of 0.75, for example, would have mass of 0.75 kg per litre, so 8 L of that material would weight 0.75 times (or 75%) of 17.6 pounds. But without that specific gravity figure, you can't convert litres to pounds.
Feb 09, 2011 | Office Equipment & Supplies
WHAT IS THE FUEL/OIL MIXTURE FOR A POULAN PREDITOR 2150 CHAINSAW?
if using a good quality 2 stroke oil brand
mix it @ ratio 50:1 that is 100 mils of oil per 5 litres of petrol
or on a 1 litre basis it would be 20 mils of oil per litre
but !!!! if you are using generic 2 stroke oil from a garage
run it on 25:1 mix that is 40 mils of oil per litre of petrol
be sure to put required qty of in clean container 1st then add petrol qty to the can and give good shake , then fill your saw
cheers hope it helps
paul
Jul 31, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I don't get enough water through the pump to keep it running with pressure. Pump cycles on and off.
unfortunately this is rather common problem, there is several solutions, none easy. i assume that you already cleaned inlet filter and connection hose is good diameter. check your mains if it is fully open (open tap in full then back half turn), same with tap connected to your supply hose. try to re-locate washer as close as possible to your mains connector. do bear in mind that these washers require at least 2gallons of water per minute (9 litres per minute)
if this solution do not work, or it is not feasible, find some 20 litres (5gallon) canister which can survive mains pressure, connect it with very short hose to your pressure washer and other end to mains, i know this is not an ideal solution but it will give you about 3min bursts.
if you find my advice helpful, please do not hesitate to comment and leave voe4 for me, thanx!
Jul 31, 2010 | McCulloch Garden
Proper mixture ratio for roundup weather max commercial grade.
2 ounces per gallon. you can convert gallons to liters on the net.
Apr 19, 2010 | Roundup "" Weed & Grass Killer
Aug 13, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal De
