Question about Dryers
Simplicity Dryer by Danby
Lost heat on dryer LEY47aw-1709, internal fuse or element gone on 240 V side? any easy way to tell.
    Sergeant:
  • 288 Answers
An easy way to tell if the element is out is to remove it and look at it. The coil will have a burt out wire(short). As for fuses, if you have any, some can be looked at to see if bunt like the ones in your car, if not that type, then you will need a ohm meter to tell. There also is at least 1 thermal disc on the machine. Check them for burnt wires or test with the meter if available.
Posted on Dec 23, 2007
Put new thermal limiting switch, thermal fuse and heating element in my whirlpool estate elec. dryer. it will not get hot still is there something i,m missing?
their are several possibilities
1) check breaker and or fuse to be supplying 240 volts to the dryer,even though the breaker seems to be on a internal burned out breaker will appear to be set but 240 vac not at dryer
2) check were the cord connects to back of dryer that one on the legs hasnt burnt and only 120 vac to dryer instead or required 240 vac
3)depending on your model i dont know if you have a timer or computer control but it isn't sending power to the element
4) the motor switch could be defective, all dryers are required by law to have a built in safety that assures the dryer will not heat when it isn't running to do that all dryers have a switch built into the motor that will only send power to the element once its running
5) in addation to the high limit t-stat and thermal fuse all dryers (depending on model) have a cycling t-stat or thermistor that controls the normal operating temp (the high limit and thermal fuse only come in to play when a dryer overheats) that could be defective
Jul 22, 2011 | Whirlpool Washing Machines
Kenmore cloths dryer no heat --- drum and air but no heat ---think it is therma fuse clean vents
Well it runs so that is not the thermal fuse. I would check the limits on the heater or maybe the heater itselfthemobilian_2271.jpgthemobilian_2272.jpgthemobilian_2273.jpgthemobilian_2274.jpg
If these components check ok and yall still have no heat then the timer may be bad.
or the dedicated house dryer circuit breaker is gone on the heat load side.
The motor works on 120 volts or L-1 and neutral. The 5000 watt 240 heating element needs both sides of the breaker to operate correctly. Heat can be iffy or none at all if this is the case.
I have service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 02, 2011 | Kenmore Dryers
My dryer is running, but doesn't have heat.
All electric dryers use 220-240 volts of electricity to run. The elements that make the heat are what actually need the 220 volts, the motor that turns the drum only uses 110. If you have a fused service disconnect box, replace both fuses, as one side is gone. 220/240 is made up of two 110/120 lines coming in, if one fuse, one side, blows, then all that's left is the 110/120 needed to run the drum motor, but no 220/240 to run the heat element. If there is no service disconnect then check the breaker than runs the dryer, flip it off and then back on to see if that makes any difference. Sometimes it will. Then there's the possibility that the hi-limit thermostat on the heat chamber in the machine blew, letting the drum run, but not feeding the coils. If you're not real handy with tools you may want to call a repair tech for this one.
Apr 22, 2011 | GE Profile Harmony DPGT750EC Electric...
I have no heat from the dryer I have checked the thermostats and fuses they all seam good there was 240 AC at the dryer element on both sides but no heat so I replaced the element with a new one but I...
If you have 240 between the 2 element terminals, thats a bad element . If the dryer is running in the normal dry cycle when you take the measurement you should get 0 volts. 240 shows you have a break in the circuit.
Jun 18, 2010 | Whirlpool LER4634J Electric Dryer
My maytag neptune eletric dryer is not drying my cloths only cold air circulates. checked continuity of heat element,good, no limits or fuses open, 120volts to each side of the element. What am i missing?
Should have 240 volts at element.  If it has continuity, you will read the same voltage on either side.  Check across the element for 240.  If you only have 120 check for 240 across the two outside terminals where the cord hooks up.  More than likely either a half tripped breaker or defective breaker.
Dec 19, 2009 | Maytag Neptune MDE4000 Electric Dryer
No heat in or coming out of the dryer Whirlpool LE6800XTWO
FIRST CHECK YOUR THERMAL FUSE FOR CONTINUITY IF NONE REPLACE IT AND REPOST
Apr 17, 2009 | Whirlpool LER5636P Electric Dryer
My maytag electric dryer will not heat up. it's a de107
Have someone check to be sure you have 240 volts to the plug. The dryer will run on 120 volts but must have 240 volts to the heating unit. If you 240 volts you probably need a heating element or control.
Apr 06, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Had new element but still no heat
First, you must test to make sure you have full 240 volts to the dryer across the two outside terminals where the cord connects onto the dryer. If you only are getting 120, the dryer motor may run fine, but you will not get any heating. If getting 240, list your model number so we can tell you where that thermal fuse might be on your machine.
Nov 09, 2008 | Dryers
Kenmore dryer 80 series
bbrhoades the first thing I always tell people with dryers to to 1st turn the breaker off and then back on. The reason is that only the heating element uses 240 volts, the motor is 120 volts. If this doesn't resolve the issue, then inspect the heater element for breakage. Hope this helps.
Feb 03, 2008 | Amana NDE2335AY Electric Dryer
Dryers Logo
560 people viewed this question
Top Dryers Experts
Marvin
Marvin
