Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
The colors do not line up on the left side of the screen.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
This set uses two convergence IC'S---either STK-392-110 OR STK-392-150 (THEY are both the same but the 150 is a higher current device and lasts longer.)
The reason they fail is simple. They are black and about 2 1/2 inches wide X 1 1/2 inches tall and located on two metal heat sinksThe colors do not line up on the left side of the - 2.gif side by side--each has 18 pins--the back of each chip is metal--a white grease (called heat sink compound) is applied to each chip to transfer heat quickly--after several years the grease dries out and one of them reaches a point where it does not move the heat to the metal fast enough---the chip fails.
You can buy both chips (a pair) on Ebay for less than 14 dollars plus shipping (the chips will have the STK number printed on them in white.)
If you can do this repair yourself you can save a lot of money--most shops charge 300-400 for this type of repair---I have done hundreds of them and here charge 200-250 for this repair.
If you cannot do the repair--shop around your area and find someone who can do it right in your home--if they say it has to go to the shop--keep looking as any good tech can do this repair in your home in about 1 hour.
Usually just both chips need to be replaced, sometimes there may be a burnt or discolored resistor around them that also needs to be replaced.
AFTER the chips are replaced and the set adjusted with the remote---you should not have this problem for 5-8 years......
If you need more information or have questions reply to this posting here and I will help you--I am here to help people.
Regards, SD TECH
Posted on Oct 06, 2009
I have an LG 2009 60ps60 plasma TV with multi color vertical lines on the left side of screen. Is there a board I can change to correct this problem??
1. Identify the TCON board.
2. Reset the Left side ribbon cables on the T-CON board
3. Replace CON board if you find a spare
Apr 13, 2016 | LG Televison & Video
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Recently I turned on my TV and I have vertical white area with some lines that are colored on the left side of the screen. The rest of the screen looks fine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 04, 2015 | Sharp Televison & Video
Sony KDL-52WL130 Dark and blurry on left side of screen . Also vertical lines on left side of screen
The TV requires thorough servicing and this might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
Fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Jan 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Dark transperant vertical line, left side of screen
Your light tunnel is bad. This requires partial disassembly of the light engine. Suggest contacting a tech
Dec 30, 2008 | Samsung HL-R4264W 42" DLP HDTV
2 thin blue lines on left h side of humax 32tpvr
IN THE MENU FOR COLOR CONVERSION TO REALIGN THE COLORS
Dec 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Red and green colors won't allign....
There is one way. Get way to go in to service menu and set conversions manualy. Remember to save. Tv will be ok
Dec 25, 2007 | Toshiba 46HM95 46" HDTV
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
