Question about GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator
Frost free freezer in my frost free refrigerator
My freezer is making an awful sound and has begun building up ice on the back of freezer, This was noticed today when I got in from work. Is there any solution? What could this be?
  • leaddyjenkin Oct 06, 2009
    i meant frost in my frost free freezer part of my refrigerator
    President:
  • 1,304 Answers
The noise is quite possibly the freezer fan cutting ice behind the wall
you may have an issue with your defrost system
Posted on Oct 06, 2009
Testimonial: "Thanks. It does sound like a chopping noise and I see all this ice build up on the back wall. I am not good with things like this so any help, helps."
Ice build-up in freezer
This is normal for this model. It is operating as it should.They are not a true frost free model
Mar 12, 2012 | Amana Refrigerators
My freezer is producing a lot of ice. There is buildup on the side racks, making it difficult to push/pull the top drawer. There is also frost/ice build up on the back of freezer and bottom floor. I...
This always happens when you don't have 'FROST-FREE' refrigerator. Unplug the power cord or switch off the freezer for about one hour or more when lots of frost stacks (maybe weekly). Turn down the cold lavel to 2-3 instead of higher if there are not so many items in the freezer.
Nov 12, 2010 | LG LFD22860 Bottom Freezer French Door...
FRIG SIDE ISN'T COOLING WELL, FROST IN THE BACK OF THE FREEZER AND IT ISN'T FREEZING THE ICE CREAM HARD, ALSO HASN'T MADE ICE SINCE THE PROBLEM STARTED.
sounds like it should be a frost free unit what happens is they stop auto defrosting and the ice builds up in the freezer compartment where you cant see it leave it switched off to defrost it for a couple of days or take of the pannel inside the freezer so that you can see the ice build up defrost it replace pannel then switch back on but be warned it will happen again
Apr 04, 2010 | Hotpoint Refrigerators
Our 8 year old refrigerator has recently begun making a continuous tapping sound. The sounds stops when you open the bottom freezer door.
the compresor fan is might make that sound or the fan in your freezer is tuching something like build up ice... see if you can reach it and clean it.
Jan 01, 2010 | Refrigerators
The freezer (top freezer) is making an awful noise, and there is some frost on what looks to be the fan. It sounds like the fan is whining at times. Help me.
unplug and defrost...fan is stuck with ice....make sure while in operation door shuts completely..any air will cause ice/frost build up......dont overfill freezer....thanks and have a great day
Nov 08, 2009 | Refrigerators
Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Oct 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice is building up on the back cooling panal in frost free referi
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Refrigerators
The ice dispenser door does not close all the way, and frost building up inside.
You are sure about the model number listed above your post? There are many versions of that model so I just need to confirm. Has the fresh food compartment begun to warm up slightly? Is frost building up on back freezer wall indicating a defrost problem. That model has control boards that make your refrigerator more efficient. If you need more help I will give you my email address so we can communicate directly, Thanks, Sea Breeze
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator Logo
195 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
