Question about Dryers
I have an older electric Maytag dryer-bought in 1992 or '93. The bulb when you open the dooe has burned out. A night light type bulb fits in the socket but won't light up. What bulb should I get and where can I get it?
    President:
  • 1,304 Answers
Double check the bulb again you have the right size
if you know the bulb is good and still wont come on
you probaly hve a bad circuit
Posted on Oct 06, 2009
Fix a burned out light bulb on dryer?
there should be a light bulb housing in the inside back of the dryer. most just need a screw driver to open in, just remember to unplug the dryer before do any kind of electrical work...that includes changing a light bulb. unscrew the housing, make sure not to lose any of the screws. with the correct light bulb, just replace the burnt out one with a new working one.
Dec 25, 2014 | Refrigerators
My dryer flew off of a dolly when loading it on a trailer to move it. It smells like rubber is burning when I turn the dryer on. It was working fine until we moved the dryer. Could it be the belt is loose?
If the dryer fell some distance, the drum is probably out of alignment.
If the drum is not spinning at all, something has jammed the drum and the belt is being overheated by the motor pulley.
If the drum is spinning and there is a rubber smell, the drum has been knocked off of its rollers and/or glides.
In either case, the dryer needs to be opened. Click the link below:
http://www.applianceaid.com/may-apart.html
There are two basic types of Maytag dryers, older models and the newer ones with the door that wraps over the top ('L' shaped door).
Apr 07, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Maytag dryer stopped working (model LDE9334ACE - electric). Dryer light DOES NOT work when door is open. Checked circuit breakers and that's fine.
Check your timer switch, that would cause you light not to work.
Also check the bulb, it may be burned out.
I hope this helps
Oct 01, 2009 | Maytag Dryers
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Replace the grille and screws.
Jun 26, 2009 | GE Microwave Ovens
I have a maytag dryer that has power, but the light doesnt work(but it is not burned out) and the dryer will not start. timer works, can anyone tell me what could be the problem
You probably have a bad door switch. When the door is open, the switch should turn on the light. When the door is closed, the switch should allow the dryer to start.
Jun 15, 2009 | Maytag PYE2300AY Electric Dryer
When i open the door light does not come on
I'm assuming this is a dryer and if the dryer still stops when you open the door then the switch to stop the dryer and light the light is probably working so it sounds like the bulb burn't out.
Locate the bulb and remove it. It's probably only a couple of screws and a bulb that you push in and twist to remove. Inspect the bulb and if it looks bad call around for a replacement and remember to take the old bulb with you to verify the replacement is the same.
Hope this was helpful.
Good Luck!
Jan 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Gas dryer Maytag model # LDG410
You don't light the pilot. Gas dryers have a glow bar type ignitor. These get very fragile with age and will burn out like a light bulb. The other thing that will wipe out the glowbar is moving the machine if it gets handled roughly.
Jan 02, 2009 | Maytag MDG7600AW Gas Dryer
Beeping noise at night
possible glitch from main power from house ,, or main control board failure
Nov 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Dryer
the high limit switch may be malfunctioning. i would have it looked at by a professional. this could be a fire hazard.
Jul 10, 2008 | Dryers
Maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Jun 07, 2008 | Dryers
Dryers Logo
79 people viewed this question
Top Dryers Experts
