Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Smelled burning then frezzer is not cold - Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
    President:
  • 1,304 Answers
You overload and relay probably burned out
they are located on the compressor
Posted on Oct 06, 2009
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge not cold enough set at 8
okay if it is not cold enough you should check the frezzer temp, and then play around with the fridge that should help. I had the same problem
Aug 08, 2009 | Master Bilt Indoor Step In Cooler 70""W x...
Frigerator doesn't get cold but frezzer works frezzer gets way to cold have to defrost every now and then and fridge is warm? dont know what's wrong it's a kemore model # 10675929400 frezzer is on...
Check to see if interior fan motor is running and blades are forcing cold air down to the lower section. New fan motors can be ordered from repairclinic.com or local parts house. Also look for blocked air ducts at back of cabinet.
Jun 09, 2009 | Refrigerators
Fridge not cold .
if there is frost building up in the frezzer on the back wall you have a defrost problem,is the frig. motor clicking on and off or just running all the time?if it runs all the time you need to unplug it so you don't burn thr comp. out,let me know what you find-mike
Nov 12, 2008 | Hoover Refrigerators
Refrigerator not getting cold
Chech blower fan POSSILE Burned UP clean coils see if fan works, or check compressor in supper HOOOT, possible burned.
Smell , does it smell like like burming tar or burned food.
Sep 26, 2008 | Sub-Zero 690 Side by Side Refrigerator
Ge profile side by side 'fridge
Evaporator fan motor and main Pcb , the fan motor goes faulty and then burns out a resistor on the main pcb at the back.
Aug 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
New Sanyo Fridge not working
I have the sam eproblem but my freezer is very cool, but the fridge wont get cold, it is just chilled, my food still goes bad and the water and soda is room tem..this doesnt make sense!
Nov 25, 2007 | Sanyo SR-1030W Top Freezer Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
87 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
