Question about Fuji FinePix A345 Digital Camera
Display reads "Card not intitialized" - Fuji FinePix A345 Digital Camera
My Mazda mx6 has delay on take off issues.
There are ALLOT OF THINGS THAT CAN CUASE THIS. Please read the article by the car pros at this web link on the common causes of hesitation.
Jul 11, 2012 | 1991 Mazda MX-6
The camera display reads "card
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
Jun 14, 2011 | Samsung S860 Digital Camera
C0000021a fatal system error the system has
If you see the System Intitialization screen then getting this error... is is most likely a corrupted Hard Drive. Hard Drive needs to be maintenaced and it may take a Tech to do it or someone real savy. Basicly you need to Boot the System from a CD, floppy or thumb drive and run ChkDsk,.. and see if that removes the error. Drive most likely read able on another system...
Jan 01, 2010 | HP Pavilion a1610n PC Desktop
Initial set up of PS3. initial set up screen not displayed
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
Apr 17, 2009 | Sony Playstation 3 (PS3) Console
Problem with windows. It won't boot up
this only problem with windows or virus....
you can use recovery to solve this problem..nothing else...check and it will work fine
Jan 08, 2009 | Dell Inspiron 6000 Notebook
Gpsmap 182c
My 182C developed the same problem. It appears to be a problem with reading data from the card. When I power up the unit, sometimes it will display "Reading Card" for a long time and no data will be read. I've found that if I open the latch and push in on the card as I press the power button, it will only then display the number of maps loaded. Sometimes less than other times. Most times a lot of data is not loaded from the card causing the problem frankcps describes and other problems, such as no data for tide stations, anchorage, etc. I tried cleaning the contacts on the data card & where it plugs in, but still continue to have the problem.
Jul 26, 2008 | Garmin GPSMAP 182C GPS Receiver
My phone cannot read my memory card
same happen to my nokia 6680 it was workinf fyn but then when i put it in theres nutin on it
Jun 09, 2008 | Nokia N93 Cellular Phone
Card error displayed
OK, your not going to believe this but I had the same problem and read on another board to remove your SM Card, blow into the slot, and replace the card. I did this as a last resort and it worked. I can only get my camera to read the card if I do this before I insert it. Un-believable!
Oct 15, 2007 | Olympus Camedia C-3030 Zoom Digital Camera
Fuji FinePix A345 Digital Camera Logo
12 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
