Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the volume increases. What settings am I missing to keep the volume level Up?
Comments:
Oct 07, 2009
- Good morning Dish Fritter:
My question may have not been clear.
Without the auto volume on, the TV's sound literally has to be turned all the way up (90+) for reasonable listening. With the auto volume on, the TV sound can be set around 25-30.
It seems like the auto volume gets turned off when the TV gets turned off even though on the menu it shows that it is on.
It can be corrected by going into the main menu/sound/auto volume/yes and then the sound returns to the higher level. This is a real pain to do every time the TV gets turned on.
Hope this clarifies my question and thanks for your assistance.
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Was this helpful?
Yes
No
Popular Solutions for LG 37LG30 37 in. HDTV LCD TV
tv image keeps breaking up in the past few week. may be due to the switching off of the analogue...
(More)
tv image keeps breaking up in the past few week. may be due to the switching off of the analogue system
I'm getting an invalid format error when hooking my ps3 up to the tv through an hdmi cable. I've...
(More)
I'm getting an invalid format error when hooking my ps3 up to the tv through an hdmi cable. I've tried troubleshooting the ps3 but nothing is working and was wondering if there is some setting I need to change on the tv.
