Kenmore Elite 90 Series overflows
I have the model # 110.28922790 and no matter what size load we have it on the water will not stop running, it just overflows. We have to manually turn the knob to stop the water flow. How do we fix this problem??
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.28922790
Click on the Control Panel category and see the "Switch, Water Level", Item # 2.
AND / OR Click on the Rear Panel category and see the "Water Inlet Valve" #26
See the following PDF on how Whirlpool / Kenmore top load direct drive washers work and testing procedures for the components.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
See the following :
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Posted on Oct 07, 2009
    President:
  • 1,776 Answers
Check for a faulty water level/pressure switch. This is a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, so does the pressure on the air in the plastic tube and when it reaches a certain leve it activates the switch to shut off the water. Make sure there is no obstruction in the tube and that it is not damaged in any way. The switch can be tested using a multimeter or ohmmeter and checking continuity. A lack of continuity will mean a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Washer overflowed
What is the model number of the unit?
Nov 28, 2012 | Kenmore Elite 45986 Front Load Washer
How to fix a Kenmore 90 Series when the water keeps running?
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this will help you to fix your washer,
Gene
Aug 09, 2011 | Kenmore 22422 Top Load Washer
Fills with water till it overflows especially in rinse cycle no matter what water level setting
most probably cause is water level/pressure switch or h hose.  either needs to be replaced or hose needs cleaning or came disconnected..
Jul 20, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Lady Kenmore series 90 washer that won't stop filling not matter what load size I put it on. It fills till it over flows and still keeps going. What can I do to fix this?
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
This sounds like a stuck water inlet valve problem:
See the following Whirlpool / Kenmore Service manual for top load, direct drive washers. It has a troubleshooting section as well at testing procedures:
Also see the following site for how to gain access to the console to test the valve:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=930a97d629b9978fcff5d8d6b3db8ad5
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
I have a series 90 washer and it just stopped and is full of water. It will not power up. where should I start?
must be overload trip. drain water first. reduce load. restart. if doesn't work, check CB or fuse inside the machine
Mar 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Over running water fill
You have a bad water level selecter switch (Load size) you will need to replace. It's not hard, located inside the console and does not cost much.
Oct 09, 2009 | Kenmore Washing Machines
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Washer water wont stop running and switch to wash. It overflowed
sounds like a bad water valve. Try disconnecting for a few minutes. If problem continues, the solenoid on the water valve is staying open which means the circuit is not opening. Replace valve.
Jun 29, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series washer overfills
your pressure switch may be bad or your hose that goes from your tub to your switch may be clogged with gunk
Mar 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
